第三方数据源配置找不到了
报错信息:
2022/09/08 13:41:28 MemoryConnection_Datasource_Checker-15-worker-1 ERROR [standard]  Cannot find key :FRDemo in Map, this may cause inconsistency!
2022/09/08 13:41:28 MemoryConnection_Datasource_Checker-15-worker-1 ERROR [standard]  Cannot find key :BI Demo in Map, this may cause inconsistency!
2022/09/08 13:41:28 MemoryConnection_Datasource_Checker-15-worker-1 ERROR [standard]  Cannot find key :aida_da_weimob in Map, this may cause inconsistency!
2022/09/08 13:41:28 MemoryConnection_Datasource_Checker-15-worker-1 ERROR [standard]  Cannot find key :aida_saas in Map, this may cause inconsistency!
2022/09/08 13:41:28 MemoryConnection_Datasource_Checker-15-worker-1 ERROR [standard]  Cannot find key :ai_aida_da_weimob in Map, this may cause inconsistency!
2022/09/08 13:41:28 MemoryConnection_Datasource_Checker-15-worker-1 ERROR [standard]  Cannot find key :ai_saas_buried in Map, this may cause inconsistency!
2022/09/08 13:41:28 MemoryConnection_Datasource_Checker-15-worker-1 ERROR [standard]  Cannot find key :aida_saas_buried in Map, this may cause inconsistency!
FineBI yzm186615 发布于 2022-9-8 13:57
发布于2023-3-17 19:37
应该是findb数据库的数据连接丢失或损坏了,有备份的话,还原下备份
没有的话,只能重新定义这些数据连接了
zhangcgLv5见习互助
发布于2023-4-18 17:03
遇到相同问题
  • 264浏览人数
  • 最后回答于:2023-4-18 17:03
