关于tomcat部署的决策系统启动后无法登陆的问题。
如题,经常报如下错误:
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=5120m; support was removed in 8.0
02-Aug-2019 09:54:29.175 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Server version:        Apache Tomcat/8.5.39
02-Aug-2019 09:54:29.178 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:          Mar 14 2019 11:24:26 UTC
02-Aug-2019 09:54:29.179 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Server number:         8.5.39.0
02-Aug-2019 09:54:29.179 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name:               Windows 10
02-Aug-2019 09:54:29.179 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version:            10.0
02-Aug-2019 09:54:29.179 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture:          amd64
02-Aug-2019 09:54:29.180 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home:             D:\Java\jdk1.8.0_191\jre
02-Aug-2019 09:54:29.180 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:           1.8.0_191-b12
02-Aug-2019 09:54:29.181 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:            Oracle Corporation
02-Aug-2019 09:54:29.181 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:         D:\Program Files\apache-tomcat-8.5.39
02-Aug-2019 09:54:29.181 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:         D:\Program Files\apache-tomcat-8.5.39
02-Aug-2019 09:54:29.181 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=D:\Program Files\apache-tomcat-8.5.39\conf\logging.properties
02-Aug-2019 09:54:29.181 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
02-Aug-2019 09:54:29.182 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms1024M
02-Aug-2019 09:54:29.182 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx5120M
02-Aug-2019 09:54:29.182 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:MaxPermSize=5120m
02-Aug-2019 09:54:29.183 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
02-Aug-2019 09:54:29.183 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
02-Aug-2019 09:54:29.183 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
02-Aug-2019 09:54:29.184 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=D:\Program Files\apache-tomcat-8.5.39
02-Aug-2019 09:54:29.184 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=D:\Program Files\apache-tomcat-8.5.39
02-Aug-2019 09:54:29.184 淇℃伅 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=D:\Program Files\apache-tomcat-8.5.39\temp
02-Aug-2019 09:54:29.185 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded APR based Apache Tomcat Native library [1.2.21] using APR version [1.6.5].
02-Aug-2019 09:54:29.185 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
02-Aug-2019 09:54:29.185 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true]
02-Aug-2019 09:54:29.190 淇℃伅 [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 1.1.1a  20 Nov 2018]
02-Aug-2019 09:54:29.288 淇℃伅 [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
02-Aug-2019 09:54:29.383 淇℃伅 [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
02-Aug-2019 09:54:29.391 淇℃伅 [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
02-Aug-2019 09:54:29.393 淇℃伅 [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
02-Aug-2019 09:54:29.394 淇℃伅 [main] org.apache.catalina.startup.Catalina.load Initialization processed in 543 ms
02-Aug-2019 09:54:29.413 淇℃伅 [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
02-Aug-2019 09:54:29.413 淇℃伅 [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.39
02-Aug-2019 09:54:29.421 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\docs]
02-Aug-2019 09:54:29.650 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\docs] has finished in [229] ms
02-Aug-2019 09:54:29.652 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\examples]
02-Aug-2019 09:54:29.938 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\examples] has finished in [286] ms
02-Aug-2019 09:54:29.938 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\host-manager]
02-Aug-2019 09:54:29.964 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\host-manager] has finished in [26] ms
02-Aug-2019 09:54:29.964 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\manager]
02-Aug-2019 09:54:29.990 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\manager] has finished in [26] ms
02-Aug-2019 09:54:29.990 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\ROOT]
02-Aug-2019 09:54:30.014 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\ROOT] has finished in [24] ms
02-Aug-2019 09:54:30.014 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\webroot]
[INFO]Starting fine assist...
[INFO]Temp file path :D:\Program Files\apache-tomcat-8.5.39\temp
[INFO]Fine assist start successfully.
[INFO]Starting fine runtime...
[INFO]Fine runtime started.
[DEBUG]Module not found cluster-collections
[DEBUG]Module not found finebi-start-foundation
[DEBUG]Module not found finebi-start-direct
[DEBUG]Module not found finebi-start-swift
[DEBUG]Module not found finebi-decision-dependency
[DEBUG]Module not found finebi-update
[DEBUG]Module not found decision-bi
[DEBUG]Module not found schedule-bi
[INFO]Module VirtualActivator starting...
[INFO]Module ServerBasicActivator starting...
[INFO]Module BasicActivator starting...
[INFO]Success to start fine analyzer: sun.instrument.InstrumentationImpl@2476e513.
[INFO]Success to install instrumentation.
[DEBUG]Dynamic transform successfully:class com.fr.base.EmailManager
[INFO]Module I18nActivator starting...
[INFO]Module I18nActivator started.Time used 2 ms.
[INFO]Module DefaultLogActivator starting...
09:54:40 localhost-startStop-1 INFO [standard] Module DefaultLogActivator started.Time used 89 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module ClassFactoryActivator starting...
09:54:40 localhost-startStop-1 INFO [standard] Module ClassFactoryActivator started.Time used 1 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module SerializationActivator starting...
09:54:40 localhost-startStop-1 INFO [standard] Module SerializationActivator started.Time used 3 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module JsonSerializationActivator starting...
09:54:40 localhost-startStop-1 INFO [standard] Module JsonSerializationActivator started.Time used 207 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module WorkspaceActivator starting...
09:54:40 localhost-startStop-1 INFO [standard] Module WorkspaceRegister starting...
09:54:40 localhost-startStop-1 INFO [standard] Module WorkspaceRegister started.Time used 0 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module WorkspaceActivator started.Time used 9 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module XMLableActivator starting...
09:54:40 localhost-startStop-1 INFO [standard] Module XMLableActivator started.Time used 3 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module BasicActivator started.Time used 1119 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module ServerWorkspaceProvider starting...
09:54:40 localhost-startStop-1 INFO [standard] Module ServerWorkspaceProvider started.Time used 14 ms.
09:54:40 localhost-startStop-1 INFO [standard] Module CoreActivator starting...
09:54:41 localhost-startStop-1 INFO [standard] Module BaseResourceActivator starting...
09:54:41 localhost-startStop-1 INFO [standard] Module BaseResourceActivator started.Time used 0 ms.
09:54:41 localhost-startStop-1 INFO [standard] Module BaseDBActivator starting...
09:54:41 pool-4-thread-1 ERROR [com.fr.third.alibaba.druid.pool.DruidDataSource] testOnBorrow is true, validationQuery not set
09:54:41 pool-4-thread-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource] {dataSource-1} inited
八月 02, 2019 9:54:42 上午 com.fr.third.org.hibernate.type.descriptor.java.JavaTypeDescriptorRegistry getDescriptor
WARN: Could not find matching type descriptor for requested Java class [java.util.List]; using fallback
WARN: Could not find matching type descriptor for requested Java class [com.fr.swift.source.alloter.AllotRule]; using fallback
09:54:43 localhost-startStop-1 INFO [standard] Module BaseDBActivator started.Time used 2530 ms.
09:54:43 localhost-startStop-1 INFO [standard] Module ConfigurationActivator starting...
09:54:43 localhost-startStop-1 INFO [standard] Module ConfigurationActivator started.Time used 297 ms.
09:54:43 localhost-startStop-1 INFO [standard] Module VirtualActivator starting...
09:54:43 localhost-startStop-1 INFO [standard] Module FineLoggerActivator starting...
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
java.util.ServiceConfigurationError: com.sun.tools.attach.spi.AttachProvider: Provider sun.tools.attach.WindowsAttachProvider could not be instantiated
size11Thread-13
09:54:51 CommonExecutor-1-thread-1 ERROR [com.fr.third.alibaba.druid.pool.DruidDataSource] testOnBorrow is true, validationQuery not set
 八月 02, 2019 9:54:51 上午 com.fr.third.org.hibernate.type.descriptor.java.JavaTypeDescriptorRegistry getDescriptor
09:54:53 localhost-startStop-1 ERROR [com.fr.third.alibaba.druid.pool.DruidDataSource] testOnBorrow is true, validationQuery not set
 八月 02, 2019 9:54:53 上午 com.fr.third.org.hibernate.type.descriptor.java.JavaTypeDescriptorRegistry getDescriptor
02-Aug-2019 09:55:02.545 淇℃伅 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [D:\Program Files\apache-tomcat-8.5.39\webapps\webroot] has finished in [32,530] ms
02-Aug-2019 09:55:02.552 淇℃伅 [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
02-Aug-2019 09:55:02.565 淇℃伅 [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
02-Aug-2019 09:55:02.577 淇℃伅 [main] org.apache.catalina.startup.Catalina.start Server startup in 33183 ms
八月 02, 2019 9:56:02 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: SQL Warning Code: -1100, SQLState: 02000
WARN: no data
八月 02, 2019 9:56:50 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
八月 02, 2019 9:57:28 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
八月 02, 2019 9:57:42 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
八月 02, 2019 9:58:12 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
八月 02, 2019 9:59:36 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
八月 02, 2019 10:01:03 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
八月 02, 2019 10:01:33 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
size12http-nio-8080-exec-5
size3http-nio-8080-exec-5
八月 02, 2019 10:04:14 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
八月 02, 2019 10:04:23 上午 com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper$StandardWarningHandler logWarning
WARN: no data
登陆界面登陆不进去,各位大神这个是什么原因造成的。
FineReport liu842003 发布于 2019-8-2 10:06
  • 1499浏览人数
  • 最后回答于:2019-8-2 10:06
