oracle的写法,一个人多个角色取最高权限的角色
权限大小: 管理员>用户主管>用户经理
比如
用户A  有3个角色
用户A  管理员
用户A  用户主管
用户A  用户经理
结果→
用户A 管理员
FineReport yunliwuli 发布于 2022-12-14 16:22 (编辑于 2022-12-14 16:23)
1659491276Lv2见习互助
发布于2022-12-14 16:40
看看这个方法能不能帮助你打开思路解决问题:
with t1 as (
select '用户A' as user_name,'管理员' as role_name,'123' as other from dual union all
select '用户A' as user_name,'用户主管' as role_name,'456' as other from dual union all
select '用户A' as user_name,'用户经理' as role_name,'789' as other from dual
t2 as (
select '权限大小第1' as role_order,'管理员' as role_name from dual union all
select '权限大小第2' as role_order,'用户主管' as role_name from dual union all
select '权限大小第3' as role_order,'用户经理' as role_name from dual
t3 as (
select t1.user_name,
       t1.role_name,
       t1.other,
       t2.role_order,
       row_number() over(partition by t1.user_name order by t2.role_order asc) as rn
  from t1 left join t2 on (t2.role_name = t1.role_name)
select * from t3 where t3.rn = 1;
发布于2022-12-15 08:24
你这个用汉字举例,说得有问题,有三个角色,然后知道是管理员,但是假如另一个用户的角色是:    用户主管,用户总监,用户总经理,,用汉字判断不了哪一个角色是最高的呀。你得有一个对照的表才可以。至少要有一个表里面可以标识出来,这样查询的时候就可以判断
  • 363浏览人数
  • 最后回答于:2022-12-15 08:24
