SQL两列相除报错
标准成本/价格单位显示报错,
SELECT LFGJA*100+LFMON as "期间",MATNR as "品号",VERPR/PEINH as "实际成本",STPRS/PEINH  as "标准成本"
FROM "SAPABAP1"."MBEWH"
where 1=1  ${if(len(期间) == 0,""," and LFGJA*100+LFMON = '" + 期间 + "'")}  and BWKEY = '1012'
FineReport SQL ChaoniubiH 发布于 2023-2-13 15:32
发布于2023-2-13 15:35(编辑于 2023-2-13 15:36)
SqlServer:
SELECT LFGJA*100+LFMON as "期间",MATNR as "品号",(CASE WHEN ISNULL(PEINH,0)=0 THEN NULL ELSE VERPR/PEINH END) as "实际成本",STPRS/PEINH  as "标准成本"
ORACLE:
SELECT LFGJA*100+LFMON as "期间",MATNR as "品号",(CASE WHEN NVL(PEINH,0)=0 THEN NULL ELSE VERPR/PEINH END) as "实际成本",STPRS/PEINH  as "标准成本"
MYSQL
SELECT LFGJA*100+LFMON as "期间",MATNR as "品号",(CASE WHEN IFNULL(PEINH,0)=0 THEN NULL ELSE VERPR/PEINH END) as "实际成本",STPRS/PEINH  as "标准成本"
  • ChaoniubiH ChaoniubiH(提问者) SAPhana数据库呢
    2023-02-13 15:49
  • Z4u3z1 Z4u3z1 回复 ChaoniubiH(提问者) https://www.likecs.com/show-308350036.html#sc=1200 参考这个
    2023-02-13 15:53
YmengLv5中级互助
发布于2023-2-13 15:36(编辑于 2023-2-13 15:40)
看一下有没有分母为零的数据,分母最好做个为0判断
发布于2023-2-13 15:36
你是什么数据库?你看一下你的数据格式。里面是不是有空格的行,或者其它不可见的字符,或者是文本的,还有如果不相除的话,只写字段是否报错,把明细拉出来看
  • 284浏览人数
  • 最后回答于:2023-2-13 15:40
