sql如下,当前取得是每一天的早八到晚八的数据,怎么才能取当天晚八到第二天早八的数据呢
select
s,sum(gs) as num,dt from
(select case
when left(Start,2)='XS'then Start else
left(Start,2) end s,DATEDIFF(ss,ReqTime,EndTime) as gs
,CONVERT(NVARCHAR(10),ReqTime) as dt--ReqTime,EndTime
from test
where ReqTime is not null
and [ReqTime] between '${kssj}' and '${jssj}'
and left(Start,2) !='XS'
and SUBSTRING(ReqTime,12,2)>='08'and SUBSTRING(ReqTime,12,2)<'20'
) a
group by s,dt
FineReport Vessel1213 发布于 2023-2-17 17:18
发布于2023-2-17 17:24
select
(select case
from test
and [ReqTime] between '${FORMAT(kssj,"yyyy-MM-dd 20:00:00")}' and '${FORMAT(jssj,"yyyy-MM-dd 08:00:00")}'
--and SUBSTRING(ReqTime,12,2)>='08'and SUBSTRING(ReqTime,12,2)<'20'
) a
group by s,dt
fine工具人Lv5见习互助
发布于2023-2-17 17:30(编辑于 2023-2-17 18:24)
and SUBSTRING(ReqTime,12,2) in('20','21','22','23','24','00','01','02','03','04','05','06','07')
或者
and (SUBSTRING(ReqTime,12,2)<'08' or SUBSTRING(ReqTime,12,2)>='20')
  • 349浏览人数
  • 最后回答于:2023-2-17 18:24
