phoenix实时数据可视化预览报错
错误代码:62400001The SQL : {  select "T_94FBDE"."id" "PA_0" from (select * from "school") "T_94FBDE" limit 1000  } is wrong,  please check!ERROR 1001 (42I01): Undefined column family. familyName=T_94FBDE.null
FineBI 用户R9502024 发布于 2023-3-12 15:40
发布于2023-3-12 16:04
为什么用双引号把这个临时表引起来?你是什么数据库
改成下面看一下
select
T_94FBDE.*
from (select * from "school") T_94FBDE
limit 1000
  • 用户R9502024 用户R9502024(提问者) FineBI在数据预览时报的错,语句是系统生成的。是phoenix映射HBase表数据查询语句,表名和字段都是双引号
    2023-03-12 16:09
  • CD20160914 CD20160914 回复 用户R9502024(提问者) 你用我上面的改一下测试看看
    2023-03-12 16:10
  • 用户R9502024 用户R9502024(提问者) 回复 CD20160914 Error: ERROR 1001 (42I01): Undefined column family. familyName=T_94FBDE.null (state=42I01,code=1001) org.apache.phoenix.schema.ColumnFamilyNotFoundException: ERROR 1001 (42I01): Undefined column family. familyName=T_94FBDE.null at org.apache.phoenix.schema.PTableImpl.getColumnFamily(PTableImpl.java:787) at org.apache.phoenix.compile.ProjectionCompiler.projectTableColumnFamily(ProjectionCompiler.java:262) at org.apache.phoenix.compile.ProjectionCompiler.compile(ProjectionCompiler.java:393) at org.apache.phoenix.compile.QueryCompiler.compileSingleFlatQuery(QueryCompiler.java:538) at org.apache.phoenix.compile.QueryCompiler.compileSingleQuery(QueryCompiler.java:489) at org.apache.phoenix.compile.QueryCompiler.compileSelect(QueryCompiler.java:201) at org.apache.phoenix.compile.QueryCompiler.compile(QueryCompiler.java:158) at org.apache.phoenix.jdbc.PhoenixStatement$ExecutableSelectStatement.compilePlan(PhoenixStatement.java:381) at org.apache.phoenix.jdbc.PhoenixStatement$ExecutableSelectStatement.compilePlan(PhoenixStatement.java:355) at org.apache.phoenix.jdbc.PhoenixStatement$1.call(PhoenixStatement.java:261) at org.apache.phoenix.jdbc.PhoenixStatement$1.call(PhoenixStatement.java:256) at org.apache.phoenix.call.CallRunner.run(CallRunner.java:53) at org.apache.phoenix.jdbc.PhoenixStatement.executeQuery(PhoenixStatement.java:255) at org.apache.phoenix.jdbc.PhoenixStatement.execute(PhoenixStatement.java:1436) at sqlline.Commands.execute(Commands.java:822) at sqlline.Commands.sql(Commands.java:732) at sqlline.SqlLine.dispatch(SqlLine.java:808) at sqlline.SqlLine.begin(SqlLine.java:681) at sqlline.SqlLine.start(SqlLine.java:398) at sqlline.SqlLine.main(SqlLine.java:292)
    2023-03-12 16:16
用户6NWif5139660Lv6资深互助
发布于2023-3-12 20:03
  • 612浏览人数
  • 最后回答于:2023-3-12 20:03
