代码问题
错误代码:62400001You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'varchar(20),a.CreatedOn,23) as 出货日期, --e.Code1 as 含量结构,e.Code as' at line 7
FineBI yzmBraJi9494674 发布于 2023-4-17 13:45
用户6NWif5139660Lv6资深互助
发布于2023-4-17 13:51
  • 151浏览人数
  • 最后回答于:2023-4-17 13:51
