饼图自定义标签问题
想要实现份额小于7的不显示箭头,写了一个JS,但是报错了,请各位老师看看怎么改function(){ var cl = this.seriesName; var sql = "map('"+cl+"','纯电动续航里程饼图当年',2,5)"; var sql1="map('"+cl+"','纯电动续航里程饼图当年',2,4)"; var value1 = FR.remoteEvaluate(sql); var value2 = FR.remoteEvaluate(sql1); var value=(Number(value1)*100).toFixed(0); var value3=(Number(value2)*100).toFixed(0); if(value <0 && value3>7){ return '
<img src ="../../help/picture/jiantou/向下箭头.png"  width="15" height="25" align="middle">
'; } else if (value >0 && value3>7){   return '
<img src ="../../help/picture/jiantou/向上箭头.png"  width="15" height="25" align="middle">
FineReport yzm188248 发布于 2023-5-23 15:43
YmengLv5中级互助
发布于2023-5-23 16:35
function(){
return '<img src ="../../help/picture/jiantou/向下箭头.png"  width="15" height="25" align="middle">';
return '<img src ="../../help/picture/jiantou/向上箭头.png"  width="15" height="25" align="middle">';
else{
return "";
发布于2023-5-23 15:47
  • 387浏览人数
  • 最后回答于:2023-5-23 16:35
