AWT-EventQueue-0 java.lang.NullPointerException
log.zip
开发了个插件,但是在本地 debug 的时候,选择定义数据连接的时候一直处于加载中。看到报错信息如下:(看到贴的错误码很乱,已经放在附件了)
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException at com.fr.design.data.datapane.connect.ConnectionManagerPane.populate(ConnectionManagerPane.java:38) at com.fr.design.data.datapane.connect.ConnectionListPane$5.complete(ConnectionListPane.java:378) at com.fr.design.gui.frpane.LoadingBasicPane$1.done(LoadingBasicPane.java:44) at javax.swing.SwingWorker$5.run(SwingWorker.java:737) at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(SwingWorker.java:832) at sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:112) at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker.java:842) at javax.swing.Timer.fireActionPerformed(Timer.java:313) at javax.swing.Timer$DoPostEvent.run(Timer.java:245) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at com.fr.design.carton.EventDispatchThreadHangMonitor.dispatchEvent(EventDispatchThreadHangMonitor.java:330) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109) at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235) at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233) at java.security.AccessController.doPrivileged(Native Method) at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233) at java.awt.Dialog.show(Dialog.java:1084) at java.awt.Component.show(Component.java:1671) at java.awt.Component.setVisible(Component.java:1623) at java.awt.Window.setVisible(Window.java:1014) at java.awt.Dialog.setVisible(Dialog.java:1005) at com.fr.design.data.datapane.connect.ConnectionListPane.showDialog(ConnectionListPane.java:383) at com.fr.design.os.impl.DatabaseDialogAction.openDesignDatabaseManager(DatabaseDialogAction.java:26) at com.fr.design.os.impl.DatabaseDialogAction.execute(DatabaseDialogAction.java:21) at com.fr.design.actions.server.ConnectionListAction.actionPerformed(ConnectionListAction.java:68) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886) at java.awt.Component.processMouseEvent(Component.java:6539) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6304) at java.awt.Container.processEvent(Container.java:2239) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2297) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476) at java.awt.Container.dispatchEventImpl(Container.java:2283) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84) at java.awt.EventQueue$4.run(EventQueue.java:733) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.awt.EventQueue.dispatchEvent(EventQueue.java:730) at com.fr.design.carton.EventDispatchThreadHangMonitor.dispatchEvent(EventDispatchThreadHangMonitor.java:330) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
帮忙看下,我的插件哪里的问题,造成无法使用的。
2023.06.08
根据错误信息,对 IDEA 反编译的代码进行 debug ,发现是 connectionListPane 为 null ,造成空指针。请问下,是什么原因引起的 connectionListPane 为空的?
FineReport jerome Li 发布于 2023-6-7 15:44 (编辑于 2023-6-8 10:38)
privacyLv5初级互助
发布于2023-6-7 16:28
空指针异常(NullPointerException)。它出现在AWT事件队列的主线程(AWT-EventQueue-0),并且是在com.fr.design.data.datapane.connect.ConnectionManagerPane.populate(ConnectionManagerPane.java:38)这个方法中引发的。具体的原因需要查看代码,但从异常信息中可以看出,这个错误出现的原因可能是因为在这个方法中有调用了一个空对象的方法或属性。
  • 帆软用户2tYJnhknRq 帆软用户2tYJnhknRq(提问者) 谢谢回答。目前看到的日志,全是帆软的代码报错,没有显示出来和我代码相关的错误,日志不够详细,没有把问题抛出来。
    2023-06-07 16:50
  • 1358浏览人数
  • 最后回答于:2023-6-8 10:38
