2023/06/14 10:55:48 localhost-startStop-1 ERROR [standard] com.fr.plugin.decision.hw.security.config.SchedulePasswordUpdateConfig has the same tableName with com.fr.plugin.decision.hw.security.config.SchedulePasswordUpdateConfig
java.lang.AssertionError: com.fr.plugin.decision.hw.security.config.SchedulePasswordUpdateConfig has the same tableName with com.fr.plugin.decision.hw.security.config.SchedulePasswordUpdateConfig
at com.fr.config.ConfigContext.registerTable(ConfigContext.java)
at com.fr.config.ConfigContext.access$100(ConfigContext.java)
at com.fr.config.ConfigContext$DefaultInitial.create(ConfigContext.java)
at com.fr.config.ConfigContext.getConfigInstance(ConfigContext.java)
at com.fr.plugin.decision.hw.security.config.SchedulePasswordUpdateConfig.getInstance(Unknown Source)
at com.fr.plugin.decision.hw.security.helper.SchedulePwdEncryptService.scheduleEncryptUpdate(Unknown Source)
at com.fr.plugin.decision.hw.security.HWSecurityLifecycleMonitor$1.on(Unknown Source)
at com.fr.event.EventDispatcher.fire(EventDispatcher.java)
at com.fr.startup.FineWebApplicationStartup$SpringStarter.executeStart(FineWebApplicationStartup.java)
at com.fr.stable.lifecycle.AbstractLifecycle.start(AbstractLifecycle.java)
at com.fr.startup.FineWebApplicationInitializer$1.contextInitialized(Unknown Source)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4490)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4950)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1362)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1352)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
2023/06/14 10:55:48 localhost-startStop-1 INFO [standard] [LocalContainer] application started.
2023/06/14 10:56:07 logAsyncTask-18-thread-3 INFO [standard] [GcListener] [time:1686711367205] [type:minor update↑] [maxMemBefore:1231955809] [maxMemAfter:1231955809] [afterGc:297853952] [beforeGc:274108416] [maxOld:2863661056] [current:0]
2023/06/14 10:56:29 ScheduledThreadPool-7-thread-1 INFO [standard] CacheEvictExpiredElementsJob finished
2023/06/14 10:56:30 DirectScheduledThreadPool-14-thread-1 INFO [standard] expiredCheck start! cacheMap size:0
2023/06/14 10:56:30 DirectScheduledThreadPool-14-thread-1 INFO [standard] expiredCheck finished! cacheMap size:0 and cost time 0 ms
2023/06/14 10:56:30 DirectScheduledThreadPool-14-thread-1 INFO [standard] ***************print cacheKeyWrapperMap Info start***************
2023/06/14 10:56:30 DirectScheduledThreadPool-14-thread-1 INFO [standard] [DirectScheduledThreadPool-14-thread-1] cacheMap size:0
2023/06/14 10:56:30 DirectScheduledThreadPool-14-thread-1 INFO [standard] ***************print cacheKeyWrapperMap Info end***************
2023/06/14 10:56:30 DirectScheduledThreadPool-14-thread-1 INFO [standard] CacheExpiredCheckScheduler finished
2023/06/14 10:56:31 http-nio-37799-exec-1 INFO [standard] Login info is null! username: dlut@speedit.cn
2023/06/14 10:56:37 http-nio-37799-exec-8 INFO [standard] com.fr.decision.webservice.v10.login.LoginService#login took 63 ms.
2023/06/14 10:56:37 login_info-18-thread-1 INFO [standard] 提示代码:12400001 使用/sbin/ifconfig -a获取机器信息来验证是否注册
2023/06/14 10:56:37 http-nio-37799-exec-10 ERROR [standard] J2V8 native library not loaded (j2v8-linux-x86_64/j2v8-centos-linux-x86_64)
java.lang.IllegalStateException: J2V8 native library not loaded (j2v8-linux-x86_64/j2v8-centos-linux-x86_64)
at com.eclipsesource.v8.V8.checkNativeLibraryLoaded(V8.java:264)
at com.eclipsesource.v8.V8.createV8Runtime(V8.java:156)
at com.eclipsesource.v8.V8.createV8Runtime(V8.java:117)
at com.fr.decision.update.acquirer.AcquirerSelector.isSupportJ2v8(Unknown Source)
at com.fr.decision.update.acquirer.AcquirerSelector.<clinit>(Unknown Source)
at com.fr.decision.update.acquirer.JSEngine.getEngineName(Unknown Source)
at com.fr.decision.update.acquirer.JSEngineInfo.<clinit>(Unknown Source)
at com.fr.decision.webservice.utils.WebServiceUtils.createSystemConfig(Unknown Source)
at com.fr.decision.webservice.utils.WebServiceUtils.createSystemConfigWithLicInfo(Unknown Source)
at com.fr.web.controller.decision.entrance.Home.page(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.fr.third.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at com.fr.third.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at com.fr.third.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
at com.fr.third.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:854)
at com.fr.third.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:765)
at com.fr.third.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at com.fr.third.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at com.fr.third.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at com.fr.third.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at com.fr.third.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:488)
at com.fr.third.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:582)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:212)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:156)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
... 35 common frames omitted
Caused by: java.lang.UnsatisfiedLinkError: Could not load J2V8 library. Reasons:
no libj2v8-centos-linux-x86_64.so in java.library.path
no j2v8-centos-linux-x86_64 in java.library.path
no libj2v8-linux-x86_64.so in java.library.path
no j2v8-linux-x86_64 in java.library.path
/opt/FineBI5.1/bin/temp/libj2v8-linux-x86_64.so: /lib64/libc.so.6: version `GLIBC_2.17' not found (required by /opt/FineBI5.1/bin/temp/libj2v8-linux-x86_64.so)
at com.eclipsesource.v8.LibraryLoader.loadLibrary(LibraryLoader.java:116)
at com.eclipsesource.v8.V8.load(V8.java:77)
at com.eclipsesource.v8.V8.createV8Runtime(V8.java:152)
... 63 common frames omitted
2023/06/14 10:56:39 http-nio-37799-exec-3 INFO [standard] [LoginRefreshTokenProtectValidator] refresh token protected!
2023/06/14 10:56:43 spider-cache-clean-17-thread-1 INFO [standard] SpiderCacheCleanJob finish
2023/06/14 10:57:03 http-nio-37799-exec-8 INFO [standard] [LoginRefreshTokenProtectValidator] refresh token protected!
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] ProcessFileAnalyzer accepted analysisInfo and doing analysis
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] ProcessFileAnalyzer analysis completed and submit analysisInfo to chain
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] SignalAnalyzer accepted analysisInfo and doing analysis
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 ERROR [standard] can't find signal.log
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] SignalAnalyzer analysis completed and submit analysisInfo to chain
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] CrashLogAnalyzer accepted analysisInfo and doing analysis
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] CrashLogAnalyzer analysis completed and submit analysisInfo to chain
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] SystemCheckAnalyzer accepted analysisInfo and doing analysis
2023/06/14 10:58:24 CrashAutoHandler-2-worker-1 INFO [standard] SystemCheckAnalyzer analysis completed and submit analysisInfo to chain
2023/06/14 10:58:28 http-nio-37799-exec-9 INFO [standard] [LoginRefreshTokenProtectValidator] refresh token protected! |
