SELECT MODEL_NAME , CASE WHEN NUM2=0 THEN 0 ELSE NUM2/NUM1 END FILED1, CASE WHEN NUM2=0 THEN 1 ELSE NUM2/NUM1 END FILED2 FROM ( SELECT COUNT(A.NUMBER_ID) AS NUM1 ,C.MODEL_NAME,COUNT(B.NUMBER_ID) AS NUM2 FROM( SELECT NUMBER_ID ,MODEL_ID FROM SAJET.G_IPQC_CONFIG WHERE ENABLED ='Y' ${if(班别=='白班', "AND TO_NUMBER(SUBSTR(START_TIME,0,2))>=8 AND TO_NUMBER(SUBSTR(START_TIME,0,2))<20 AND TO_NUMBER(SUBSTR(END_TIME,0,2))>8 AND TO_NUMBER(SUBSTR(END_TIME,0,2))<=20", "AND (TO_NUMBER(SUBSTR(START_TIME,0,2))>=20 OR TO_NUMBER(SUBSTR(START_TIME,0,2))<8) AND (TO_NUMBER(SUBSTR(END_TIME,0,2))>20 OR TO_NUMBER(SUBSTR(END_TIME,0,2))<=8)")} )A LEFT JOIN SAJET.SYS_FIPQC_CONFIG B ON A.NUMBER_ID=B.NUMBER_ID AND A.MODEL_ID=B.MODEL_ID AND B.ENABLED='N' ${if(班别=='白班', "AND B.CREATE_DATE >=TO_DATE('${开始} 08:00:00','YYYY-MM-DD HH24:MI:SS') AND B.CREATE_DATE <TO_DATE('${开始} 20:00:00','YYYY-MM-DD HH24:MI:SS')", "AND B.CREATE_DATE >=TO_DATE('${开始} 20:00:00','YYYY-MM-DD HH24:MI:SS') AND B.CREATE_DATE <TO_DATE('${开始1} 08:00:00','YYYY-MM-DD HH24:MI:SS')")} LEFT JOIN SAJET.SYS_MODEL C ON A.MODEL_ID=C.MODEL_ID WHERE 1=1 GROUP BY C.MODEL_NAME) WHERE 1=1 ORDER BY MODEL_NAME |
