填报的?文件》输出》内置数据。发文件上来看看,说清楚最终要的结果是如何的
int((sum(MAPARRAY(GREPARRAY(波纹管!i5:i18,item>0),if(INDEXOFARRAY(SPLIT(item,"_"),1)=a1,INDEXOFARRAY(SPLIT(item,"_"),3),0)))+
sum(MAPARRAY(GREPARRAY(克拉管!i5:i19,item>0),if(INDEXOFARRAY(SPLIT(item,"_"),1)=a1,INDEXOFARRAY(SPLIT(item,"_"),3),0))))/60)+"小时"+mod(sum(MAPARRAY(GREPARRAY(波纹管!i5:i18,item>0),if(INDEXOFARRAY(SPLIT(item,"_"),1)=a1,INDEXOFARRAY(SPLIT(item,"_"),3),0)))+
sum(MAPARRAY(GREPARRAY(克拉管!i5:i19,item>0),if(INDEXOFARRAY(SPLIT(item,"_"),1)=a1,INDEXOFARRAY(SPLIT(item,"_"),3),0))),60)+"分钟"
