finereport安装失败
我的finereport安装程序运行后,安装向导提前终止,这是什么情况
FineReport yzm883418 发布于 2023-7-3 11:09 (编辑于 2023-7-3 11:28)
发布于2023-7-3 11:09(编辑于 2023-7-3 11:10)
右键》以管理员身份安装看看(还有安装在比如D盘一个新目录测试看)
  • yzm883418 yzm883418(提问者) 试过了,还是提前终止
    2023-07-03 11:10
  • CD20160914 CD20160914 回复 yzm883418(提问者) 你安装在D盘一个新目录看。还有报什么错误,你从哪里下载的安装程序,你是windows专业版本吗?是10还是11?
    2023-07-03 11:11
  • yzm883418 yzm883418(提问者) 回复 CD20160914 官网下的安装程序,没有报错,就是刚开始的install4j安装向导准备失败,对话框直接闪退了,后面的安装引导什么的都没出来
    2023-07-03 11:14
  • yzm883418 yzm883418(提问者) 回复 CD20160914 Started executable D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.exe at Mon Jul 03 10:55:04 2023 restrict DLL directories number of sections: 6 size of optional headers: 240 resSectionTableStart: 728 rawDataSize: 2560, rawDataOffset: 412672 sun.locale.formatasdefault is false language/country is zh_CN change working directory to D:\\实习\\FineReport_10103\\FineReport single instance mode semaphore name Local\\d:_实习_finereport_10103_finereport_windows-x64_finereport-cn.exe, code 0, value 0000000000000090 Init done Starting work number of sections: 6 size of optional headers: 240 resSectionTableStart: 728 rawDataSize: 2560, rawDataOffset: 412672 starting at 415232 verifying integrity length 553752260 checksums: 1300023802 1300023802 1300023802 1300023802 tempPath is C:\\Users\\不要翻车\\AppData\\Local\\Temp\\ tempFile is C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp Temp dir3: C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905 native lib dir is ${launcher:sys.launcherTempDirectory}\\user expanding2 ${launcher:sys.launcherTempDirectory} to C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905 in C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\user. Adding DLL directory C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\user Setting PATH (native libs) C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\user;D:\\vmware\\bin\\;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Program Files\\Bandizip\\;C:\\Program Files\\dotnet\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\EasyShare\\x86\\;C:\\Program Files (x86)\\EasyShare\\x64\\;D:\\mingw\\x86_64-12.2.0-release-win32-seh-rt_v10-rev1\\mingw64\\bin;D:\\JDK\\bin;C:\\Users\\不要翻车\\AppData\\Local\\Microsoft\\WindowsApps;D:\\Users\\不要翻车\\AppData\\Local\\Programs\\Microsoft VS Code\\bin; extracting files Included files: 16 extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4jruntime.jar (size: 1922281) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_2_1nhele3_4z24ys.png (size: 542) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4jparams.conf (size: 447988) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_3_1nhele3_r9t751.png (size: 1533) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\MessagesDefault (size: 33540) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_0_1nhele3.utf8 (size: 28349) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_1_1nhele3_pwintj.png (size: 1025) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\stats.properties (size: 15334) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_5_1nhele3_1ngx43a.icns (size: 4167) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_4_1nhele3_7qlsin.png (size: 1808) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_8_1nhele3_12vnkm1.ico (size: 9662) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\user.jar (size: 9218) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\installer.ico (size: 9662) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_7_1nhele3_16jjcvp.icns (size: 4227) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\jre.tar.gz (size: 30175269) extracting C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4j_extf_6_1nhele3_uovcq1.ico (size: 9662) extracting files done Current working dir: C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905 Full JRE path: C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\jre.tar.gz JRE included extracting JRE extracting bin\\awt.dll (size 1519528) extracting bin\\dcpr.dll (size 160168) extracting bin\\decora_sse.dll (size 86440) extracting bin\\deploy.dll (size 569256) extracting bin\\dt_shmem.dll (size 30120) extracting bin\\dt_socket.dll (size 25000) extracting bin\\eula.dll (size 136616) extracting bin\\fontmanager.dll (size 275368) extracting bin\\fxplugins.dll (size 187816) extracting bin\\glass.dll (size 261544) extracting bin\\glib-lite.dll (size 456616) extracting bin\\gstreamer-lite.dll (size 622504) extracting bin\\hprof.dll (size 158120) extracting bin\\instrument.dll (size 123816) extracting bin\\j2pcsc.dll (size 19368) extracting bin\\j2pkcs11.dll (size 63912) extracting bin\\jaas_nt.dll (size 21416) extracting bin\\jabswitch.exe (size 34216) extracting bin\\java-rmi.exe (size 15784) extracting bin\\java.dll (size 157096) extracting bin\\java.exe (size 190888) extracting bin\\JavaAccessBridge-64.dll (size 142760) extracting bin\\javacpl.cpl (size 169984) extracting bin\\javacpl.exe (size 77224) extracting bin\\javafx_font.dll (size 75176) extracting bin\\javafx_font_t2k.dll (size 540584) extracting bin\\javafx_iio.dll (size 137128) extracting bin\\javaw.exe (size 191400) extracting bin\\java_crw_demo.dll (size 30120) extracting bin\\jawt.dll (size 14760) extracting bin\\JAWTAccessBridge-64.dll (size 15784) extracting bin\\jdwp.dll (size 201640) extracting bin\\jfr.dll (size 25512) extracting bin\\jfxmedia.dll (size 139688) extracting bin\\jfxwebkit.dll (size 20753832) extracting bin\\jjs.exe (size 15784) extracting bin\\jli.dll (size 159144) extracting bin\\jp2iexp.dll (size 290216) extracting bin\\jp2launcher.exe (size 100264) extracting bin\\jp2native.dll (size 20392) extracting bin\\jp2ssv.dll (size 212904) extracting bin\\jpeg.dll (size 185768) extracting bin\\jsdt.dll (size 18856) extracting bin\\jsound.dll (size 35752) extracting bin\\jsoundds.dll (size 31656) extracting bin\\kcms.dll (size 221096) extracting bin\\keytool.exe (size 15784) extracting bin\\kinit.exe (size 16296) extracting bin\\klist.exe (size 16296) extracting bin\\ktab.exe (size 16296) extracting bin\\lcms.dll (size 231848) extracting bin\\management.dll (size 37288) extracting bin\\mlib_image.dll (size 654248) extracting bin\\msvcr100.dll (size 829264) extracting bin\\net.dll (size 94120) extracting bin\\nio.dll (size 59816) extracting bin\\npt.dll (size 19368) extracting bin\\orbd.exe (size 16296) extracting bin\\pack200.exe (size 16296) extracting bin\\policytool.exe (size 16808) extracting bin\\prism_common.dll (size 57768) extracting bin\\prism_d3d.dll (size 166312) extracting bin\\prism_es2.dll (size 47528) extracting bin\\prism_sw.dll (size 64936) extracting bin\\rmid.exe (size 15784) extracting bin\\rmiregistry.exe (size 16808) extracting bin\\server\\jvm.dll (size 8569768) extracting bin\\server\\Xusage.txt (size 1423) extracting bin\\servertool.exe (size 16808) extracting bin\\splashscreen.dll (size 234920) extracting bin\\ssv.dll (size 551848) extracting bin\\ssvagent.exe (size 66472) extracting bin\\sunec.dll (size 135080) extracting bin\\sunmscapi.dll (size 31656) extracting bin\\t2k.dll (size 253352) extracting bin\\tnameserv.exe (size 16296) extracting bin\\unpack.dll (size 80296) extracting bin\\unpack200.exe (size 197544) extracting bin\\verify.dll (size 49576) extracting bin\\w2k_lsa_auth.dll (size 24488) extracting bin\\WindowsAccessBridge-64.dll (size 111016) extracting bin\\wsdetect.dll (size 192424) extracting bin\\zip.dll (size 77736) extracting COPYRIGHT (size 3244) extracting lib\\accessibility.properties (size 155) extracting lib\\amd64\\jvm.cfg (size 634) extracting lib\\calendars.properties (size 1378) extracting lib\\charsets.jar.pack (size 1078558) extracting lib\\classlist (size 80761) extracting lib\\cmm\\CIEXYZ.pf (size 51236) extracting lib\\cmm\\GRAY.pf (size 632) extracting lib\\cmm\\LINEAR_RGB.pf (size 1044) extracting lib\\cmm\\PYCC.pf (size 274474) extracting lib\\cmm\\sRGB.pf (size 3144) extracting lib\\content-types.properties (size 5548) extracting lib\\currency.data (size 4074) extracting lib\\deploy\\ffjcext.zip (size 14130) extracting lib\\deploy\\messages.properties (size 2860) extracting lib\\deploy\\messages_de.properties (size 3306) extracting lib\\deploy\\messages_es.properties (size 3600) extracting lib\\deploy\\messages_fr.properties (size 3409) extracting lib\\deploy\\messages_it.properties (size 3223) extracting lib\\deploy\\messages_ja.properties (size 6349) extracting lib\\deploy\\messages_ko.properties (size 5719) extracting lib\\deploy\\messages_pt_BR.properties (size 3348) extracting lib\\deploy\\messages_sv.properties (size 3409) extracting lib\\deploy\\messages_zh_CN.properties (size 4072) extracting lib\\deploy\\messages_zh_HK.properties (size 3752) extracting lib\\deploy\\messages_zh_TW.properties (size 3752) extracting lib\\deploy\\splash.gif (size 65995) extracting lib\\deploy.jar.pack (size 1793756) extracting lib\\ext\\access-bridge-64.jar.pack (size 65766) extracting lib\\ext\\cldrdata.jar.pack (size 4068261) extracting lib\\ext\\dnsns.jar.pack (size 5486) extracting lib\\ext\\jaccess.jar.pack (size 37508) extracting lib\\ext\\jfxrt.jar.pack (size 4576676) extracting lib\\ext\\localedata.jar.pack (size 1333894) extracting lib\\ext\\meta-index (size 1461) extracting lib\\ext\\nashorn.jar.pack (size 882195) extracting lib\\ext\\sunec.jar (size 39773) extracting lib\\ext\\sunjce_provider.jar (size 278033) extracting lib\\ext\\sunmscapi.jar (size 32654) extracting lib\\ext\\sunpkcs11.jar (size 249280) extracting lib\\ext\\zipfs.jar.pack (size 46485) extracting lib\\flavormap.properties (size 3928) extracting lib\\fontconfig.bfc (size 3670) extracting lib\\fontconfig.properties.src (size 10479) extracting lib\\fonts\\LucidaBrightDemiBold.ttf (size 75144) extracting lib\\fonts\\LucidaBrightDemiItalic.ttf (size 75124) extracting lib\\fonts\\LucidaBrightItalic.ttf (size 80856) extracting lib\\fonts\\LucidaBrightRegular.ttf (size 344908) extracting lib\\fonts\\LucidaSansDemiBold.ttf (size 317896) extracting lib\\fonts\\LucidaSansRegular.ttf (size 698236) extracting lib\\fonts\\LucidaTypewriterBold.ttf (size 234068) extracting lib\\fonts\\LucidaTypewriterRegular.ttf (size 242700) extracting lib\\hijrah-config-umalqura.properties (size 13962) extracting lib\\images\\cursors\\cursors.properties (size 1280) extracting lib\\images\\cursors\\invalid32x32.gif (size 153) extracting lib\\images\\cursors\\win32_CopyDrop32x32.gif (size 165) extracting lib\\images\\cursors\\win32_CopyNoDrop32x32.gif (size 153) extracting lib\\images\\cursors\\win32_LinkDrop32x32.gif (size 168) extracting lib\\images\\cursors\\win32_LinkNoDrop32x32.gif (size 153) extracting lib\\images\\cursors\\win32_MoveDrop32x32.gif (size 147) extracting lib\\images\\cursors\\win32_MoveNoDrop32x32.gif (size 153) extracting lib\\javafx.properties (size 29) extracting lib\\jce.jar (size 113593) extracting lib\\jfr\\default.jfc (size 19264) extracting lib\\jfr\\profile.jfc (size 19220) extracting lib\\jfr.jar.pack (size 142258) extracting lib\\jfxswt.jar.pack (size 22583) extracting lib\\jsse.jar.pack (size 152351) extracting lib\\jvm.hprof.txt (size 4226) extracting lib\\logging.properties (size 2455) extracting lib\\management\\jmxremote.access (size 3998) extracting lib\\management\\jmxremote.password.template (size 2856) extracting lib\\management\\management.properties (size 14097) extracting lib\\management\\snmp.acl.template (size 3376) extracting lib\\management-agent.jar.pack (size 195) extracting lib\\meta-index (size 2126) extracting lib\\net.properties (size 3070) extracting lib\\plugin.jar.pack (size 491134) extracting lib\\psfont.properties.ja (size 2796) extracting lib\\psfontj2d.properties (size 10393) extracting lib\\resources.jar.pack (size 3367540) extracting lib\\rt.jar.pack (size 13641792) extracting lib\\security\\blacklist (size 3890) extracting lib\\security\\blacklisted.certs (size 1188) extracting lib\\security\\cacerts (size 94618) extracting lib\\security\\java.policy (size 2466) extracting lib\\security\\java.security (size 21746) extracting lib\\security\\javaws.policy (size 98) extracting lib\\security\\local_policy.jar (size 3527) extracting lib\\security\\trusted.libraries (size 0) extracting lib\\security\\US_export_policy.jar (size 3026) extracting lib\\sound.properties (size 1210) extracting lib\\tzdb.dat (size 102449) extracting lib\\tzmappings (size 8163) extracting LICENSE (size 40) extracting README.txt (size 46) extracting release (size 527) extracting THIRDPARTYLICENSEREADME.txt (size 178400) extracting THIRDPARTYLICENSEREADME-JAVAFX.txt (size 110114) extracting Welcome.html (size 955) untaring JRE was successful JRE is packed checking jre\\lib\\charsets.jar Unpacking JRE jre\\bin\\unpack200.exe -r \"jre\\lib\\charsets.jar.pack\" \"jre\\lib\\charsets.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\deploy.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\deploy.jar.pack\" \"jre\\lib\\deploy.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\jfr.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\jfr.jar.pack\" \"jre\\lib\\jfr.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\jfxswt.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\jfxswt.jar.pack\" \"jre\\lib\\jfxswt.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\jsse.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\jsse.jar.pack\" \"jre\\lib\\jsse.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\management-agent.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\management-agent.jar.pack\" \"jre\\lib\\management-agent.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\plugin.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\plugin.jar.pack\" \"jre\\lib\\plugin.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\resources.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\resources.jar.pack\" \"jre\\lib\\resources.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\rt.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\rt.jar.pack\" \"jre\\lib\\rt.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\access-bridge-64.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\access-bridge-64.jar.pack\" \"jre\\lib\\ext\\access-bridge-64.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\cldrdata.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\cldrdata.jar.pack\" \"jre\\lib\\ext\\cldrdata.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\dnsns.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\dnsns.jar.pack\" \"jre\\lib\\ext\\dnsns.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\jaccess.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\jaccess.jar.pack\" \"jre\\lib\\ext\\jaccess.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\jfxrt.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\jfxrt.jar.pack\" \"jre\\lib\\ext\\jfxrt.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\localedata.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\localedata.jar.pack\" \"jre\\lib\\ext\\localedata.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\nashorn.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\nashorn.jar.pack\" \"jre\\lib\\ext\\nashorn.jar\" waiting for unpack200 to finish unpack done checking jre\\lib\\ext\\zipfs.jar jre\\bin\\unpack200.exe -r \"jre\\lib\\ext\\zipfs.jar.pack\" \"jre\\lib\\ext\\zipfs.jar\" waiting for unpack200 to finish unpack done Unpacking JRE done JRE dir: C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\jre LoadDLL (0, C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\jre, 0) Got JRE location C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\jre (java exe: 0) MinVersion: 1.7, MaxVersion: Trying to load JVM-DLL from c:\\users\\不要翻车\\appdata\\local\\temp\\e4j43ac.tmp_dir1688352905\\jre\\bin\\java.exe Adding DLL directory c:\\users\\不要翻车\\appdata\\local\\temp\\e4j43ac.tmp_dir1688352905\\jre\\bin Setting PATH C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\user;D:\\vmware\\bin\\;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Program Files\\Bandizip\\;C:\\Program Files\\dotnet\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\EasyShare\\x86\\;C:\\Program Files (x86)\\EasyShare\\x64\\;D:\\mingw\\x86_64-12.2.0-release-win32-seh-rt_v10-rev1\\mingw64\\bin;D:\\JDK\\bin;C:\\Users\\不要翻车\\AppData\\Local\\Microsoft\\WindowsApps;D:\\Users\\不要翻车\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;;c:\\users\\不要翻车\\appdata\\local\\temp\\e4j43ac.tmp_dir1688352905\\jre\\bin Trying c:\\users\\不要翻车\\appdata\\local\\temp\\e4j43ac.tmp_dir1688352905\\jre\\bin\\hotspot\\jvm.dll (exists 0) Trying c:\\users\\不要翻车\\appdata\\local\\temp\\e4j43ac.tmp_dir1688352905\\jre\\bin\\client\\jvm.dll (exists 0) Trying c:\\users\\不要翻车\\appdata\\local\\temp\\e4j43ac.tmp_dir1688352905\\jre\\bin\\server\\jvm.dll (exists 1) Loading of JVM-DLL successful launching program adding options vmoptions2: exe D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.exe file: D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.vmoptions, file: 0000000000000000 vmoptions: opts2: D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.exe.vmoptions, file: 0000000000000000 vmoptions2: exe D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.exe file: D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.vmoptions, file: 0000000000000000 vmoptions: opts2: D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.exe.vmoptions, file: 0000000000000000 default vmoptions file: 0000000000000000 classpath entry classpath entries 0 vmoption count 11 vmoption 0: -Dexe4j.semaphoreName=Local\\d:_实习_finereport_10103_finereport_windows-x64_finereport-cn.exe vmoption 1: -Dexe4j.isInstall4j=true vmoption 2: -Dexe4j.moduleName=D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.exe vmoption 3: -Dsun.java.command=D:\\实习\\FineReport_10103\\FineReport\\windows-x64_FineReport-CN.exe vmoption 4: -Dexe4j.tempDir=C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905 vmoption 5: -Dexe4j.unextractedPosition=33095055 vmoption 6: -Djava.library.path=C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\user;D:\\vmware\\bin\\;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Program Files\\Bandizip\\;C:\\Program Files\\dotnet\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\EasyShare\\x86\\;C:\\Program Files (x86)\\EasyShare\\x64\\;D:\\mingw\\x86_64-12.2.0-release-win32-seh-rt_v10-rev1\\mingw64\\bin;D:\\JDK\\bin;C:\\Users\\不要翻车\\AppData\\Local\\Microsoft\\WindowsApps;D:\\Users\\不要翻车\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;;c:\\users\\不要翻车\\appdata\\local\\temp\\e4j43ac.tmp_dir1688352905\\jre\\bin vmoption 7: -Dexe4j.consoleCodepage=cp0 vmoption 8: -Dsun.java2d.noddraw=true vmoption 9: -Dinstall4j.defaultLanguage=zh_CN vmoption 10: -Djava.class.path=C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\i4jruntime.jar;C:\\Users\\不要翻车\\AppData\\Local\\Temp\\e4j43AC.tmp_dir1688352905\\user.jar Creating JVM
    2023-07-03 11:14
  • CD20160914 CD20160914 回复 yzm883418(提问者) 你电脑有没有安装jdk环境。还有你不安装在中文目录下呢
    2023-07-03 11:16
发布于2023-7-3 11:11
重启电脑
然后安装包,鼠标右键,属性,设置下兼容性,不要安装在C盘,在其他盘
坚定的小帆薯Lv7高级互助
发布于2023-7-3 11:16(编辑于 2023-7-3 11:17)
如楼上测试之后还是不行,可以考虑一下重新下载个安装包看看。
可能出现,网络问题或者拷贝传输问题,导致安装包损坏【我就碰到过】
同时安装包版本最好和系统保持一致
建议,官网下载
https://www.fanruan.com/actionform?action=active-fr
  • 408浏览人数
  • 最后回答于:2023-7-3 11:28
