SQL
select REPORTDATE,sbutype,color_gamut_max,color_gamut_min,color_gamut_avg,gamut_min_spec,gamut_type_spec from EDS_DATABASE_PUSH
WHERE REPORTDATE IN ('${REPORTDATE}')
AND SBUTYPE IN ('${SBUTYPE}')
AND LC IN ('${LC}')
AND E IN ('${E}')
AND CELLGAP IN ('${CELLGAP}')
AND MASK IN ('${MASK}')
and (1=1 ${if(len(关键词1)==0,"","and APPLY like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and type like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and sbutype like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and shiptype like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and reportdate like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and fgcode like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and resolution like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and customer like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and state like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and mutant like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and ICBU like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and PPT like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and LC like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and PI like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and CELLGAP like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and OAANDRUBBING like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and APF like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and CODEVOP like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and ITO like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and PIXELSTRUCTURE like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and OPENRATIO like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and N like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and E like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and COEFFICIENT like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and FLK like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and FLKPATTERN like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and SOURCE like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and MASK like ('%"+关键词1+"%')")}
or 1=1 ${if(len(关键词1)==0,"","and MASKTYPE like ('%"+关键词1+"%')")}
and (1=1 ${if(len(关键词2)==0,"","and APPLY like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and type like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and sbutype like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and shiptype like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and reportdate like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and fgcode like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and resolution like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and customer like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and state like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and mutant like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and ICBU like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and PPT like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and LC like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and PI like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and CELLGAP like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and OAANDRUBBING like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and APF like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and CODEVOP like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and ITO like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and PIXELSTRUCTURE like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and OPENRATIO like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and N like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and E like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and COEFFICIENT like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and FLK like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and FLKPATTERN like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and SOURCE like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and MASK like ('%"+关键词2+"%')")}
or 1=1 ${if(len(关键词2)==0,"","and MASKTYPE like ('%"+关键词2+"%')")}
FineReport 帆软用户Gwj3wAf9Te 发布于 2023-7-14 14:35 (编辑于 2023-7-14 14:36)
坚定的小帆薯Lv7高级互助
发布于2023-7-14 14:38(编辑于 2023-7-14 14:41)
并行条件,说明不存在这样的数据啊
简单来说,查询就等于
and APPLY like '%关键词1%'   and APPLY like '%关键词2%'
存在这样的数据么
或者你要的是或查询,用OR
发布于2023-7-14 14:38
这个改成or试试
shirokoLv6资深互助
发布于2023-7-14 14:40
语法看起来没有问题,估计问题就是,两个关键词都输入的时候,找不到符合条件的数据,所以没有图表
  • 242浏览人数
  • 最后回答于:2023-7-14 14:41
