yzmFYfRS9139997(提问者)确定后跳转到404,下面为页面描述
HTTP Status 404 – Not Found
Type Status Report
Message /webroot/decision/view/report
Description The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
Apache Tomcat/9.0.10
yzmFYfRS9139997(提问者) 回复 帆软用户07dVkROM39sql(\\\"FRDemo\\\",\\\"select distinct 地区 from 销量\\\",1),这段代码要加\\吗?我没有\\,
这是我的代码:
sql(\"FRDemo\",\"select distinct area_mgn as area from sec_code_mapping\",1) ,
然后把点击事件中的“地区”中文改成了area
for (var i = 0; i < area.length; i++) {
var sheet = {
reportlet: path,
area: area[i]
json.push(sheet);
