官网下载的帆软10.0报错
AWT-EventQueue-0 ERROR [standard]  sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested targetjavax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
帆软报错,不知怎么解决,求解决
看了日志:Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
AWT-EventQueue-0 ERROR [standard]  Can't get input stream from URL!
javax.imageio.IIOException: Can't get input stream from URL!
yzm792005 发布于 2023-9-6 10:00 (编辑于 2023-9-6 10:05)
悬赏:0 F币 + 添加悬赏
发布于2023-9-6 10:04
直接给你个百度网盘的下载
链接: https://pan.baidu.com/s/17bvR_0jMwkcWcl2YP8kDiw?pwd=gxmb
提取码: gxmb
  • yzm792005 yzm792005(提问者) 您昨天也评论我了,说是可能jar包坏了或者是被什么禁用了,我现在也不知道咋解决,就官网重新下载了也还是这样,之前都是可以用的
    2023-09-06 10:09
  • yzm792005 yzm792005(提问者) 我看了日志,您能帮我分析一下吗
    2023-09-06 10:09
  • snrtuemc snrtuemc 回复 yzm792005(提问者) 我怀疑是你们网络被禁止了,或者电脑有什么软件,换个网络或者换台电脑测试下,你可以安装虚拟机看看
    2023-09-06 10:10
  • yzm792005 yzm792005(提问者) 回复 snrtuemc 谢谢!确实是网络有问题,如果网络有问题咋办呀,只能用那个网络
    2023-09-06 10:17
  • snrtuemc snrtuemc 回复 yzm792005(提问者) 那个让你们网管开下,第一次连接后应该就不需要网络了
    2023-09-06 10:20
  • 0关注人数
  • 281浏览人数
  • 最后回答于:2023-9-6 10:05
