移动端频繁闪退,手机提示应用程序有故障,手机报错信息如下
java.lang.IndexOutOfBoundsException: Index: 4, Size: 4
at java.util.ArrayList.get(ArrayList.java:437)
at com.finereact.report.module.a.g.a(Grid.java:27)
at com.finereact.report.module.l.d(SimpleAdapter.java:197)
at com.finereact.report.module.l.a(SimpleAdapter.java:177)
at android.support.v7.widget.RecyclerView$p.a(RecyclerView.java:5820)
at android.support.v7.widget.RecyclerView$p.a(RecyclerView.java:5752)
at android.support.v7.widget.RecyclerView$p.c(RecyclerView.java:5748)
at com.finereact.base.widget.TableLayoutManager$f.a(TableLayoutManager.java:1549)
at com.finereact.base.widget.TableLayoutManager$f.a(TableLayoutManager.java:1533)
at com.finereact.base.widget.TableLayoutManager$f.a(TableLayoutManager.java:1462)
at com.finereact.base.widget.TableLayoutManager.a(TableLayoutManager.java:719)
at com.finereact.base.widget.TableLayoutManager.a(TableLayoutManager.java:649)
at com.finereact.base.widget.TableLayoutManager.a(TableLayoutManager.java:190)
at com.finereact.base.widget.TableLayoutManager.b(TableLayoutManager.java:170)
at android.support.v7.widget.RecyclerView.a(RecyclerView.java:1815)
at android.support.v7.widget.RecyclerView.onTouchEvent(RecyclerView.java:3076)
at com.finereact.base.widget.a.onTouchEvent(BlockableTableView.kt:72)
at android.view.View.dispatchTouchEvent(View.java:15070)
at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:3135)
at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2802)
at com.finereact.base.widget.a.dispatchTouchEvent(BlockableTableView.kt:43)
at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:3148)
at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2816)
at com.finereact.report.module.d.dispatchTouchEvent(FCTReportComponent.java:445)
at com.android.internal.policy.DecorView.superDispatchTouchEvent(DecorView.java:571)
at com.android.internal.policy.PhoneWindow.superDispatchTouchEvent(PhoneWindow.java:1899)
at android.app.Activity.dispatchTouchEvent(Activity.java:4411)
at com.android.internal.policy.DecorView.dispatchTouchEvent(DecorView.java:529)
at android.view.View.dispatchPointerEvent(View.java:15345)
at android.view.ViewRootImpl$ViewPostImeInputStage.processPointerEvent(ViewRootImpl.java:7038)
at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess(ViewRootImpl.java:6808)
at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:6227)
at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:6284)
at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:6250)
at android.view.ViewRootImpl$AsyncInputStage.forward(ViewRootImpl.java:6415)
at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:6258)
at android.view.ViewRootImpl$AsyncInputStage.apply(ViewRootImpl.java:6472)
at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:6231)
at android.view.ViewRootImpl.deliverInputEvent(ViewRootImpl.java:9410)
at android.view.ViewRootImpl.doProcessInputEvents(ViewRootImpl.java:9361)
at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:9329)
at android.view.ViewRootImpl$WindowInputEventReceiver.onInputEvent(ViewRootImpl.java:9549)
at android.view.InputEventReceiver.dispatchInputEvent(InputEventReceiver.java:298)
at android.view.InputEventReceiver.nativeConsumeBatchedInputEvents(Native Method)
at android.view.InputEventReceiver.consumeBatchedInputEvents(InputEventReceiver.java:270)
at android.view.ViewRootImpl.doConsumeBatchedInput(ViewRootImpl.java:9495)
at android.view.ViewRootImpl$ConsumeBatchedInputRunnable.run(ViewRootImpl.java:9640)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1459)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1467)
at android.view.Choreographer.doCallbacks(Choreographer.java:1089)
at android.view.Choreographer.doFrame(Choreographer.java:995)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:1435)
at android.os.Handler.handleCallback(Handler.java:942)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loopOnce(Looper.java:211)
at android.os.Looper.loop(Looper.java:300)
at android.app.ActivityThread.main(ActivityThread.java:8401)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:559)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:954)
FineMobile(移动客户端) ZZZ 发布于 2023-9-7 23:39 (编辑于 2023-9-7 23:40)
悬赏:0 F币 + 添加悬赏
  • 99浏览人数
  • 最后回答于:2023-9-7 23:40
