当前驱动加载路径:D:\FineReport_11.0\webapps\webroot\WEB-INF\lib\ojdbc14.jar java.sql.SQLException: Listener refused the connection with the following error: ORA-12505, TNS:listener does not currently know of SID given in connect descriptor The Connection descriptor used by the client was: oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java.111) oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java.260) oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java.386) oracle.jdbc.driver.PhysicalConnection. oracle.jdbc.driver.T4CConnection. oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java.34) oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java.752) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1666) com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java.1732) com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java.2907) |
