本地帆软11设计器无法连接帆软10服务器
如下所示,连接帆软10服务器失败。但后面测试连接11服务器端正常。是否不支持?
com.fr.workspace.engine.exception.RemoteDesignConnectionException: com.fr.workspace.engine.exception.WorkspaceConnectionException: Response HTTP/1.1 404  by 192.168.18.189:8085
at com.fr.workspace.engine.convert.NetworkConnectionErrorConverter.convert(NetworkConnectionErrorConverter.java)
at com.fr.workspace.engine.convert.ExceptionConverter.convert(ExceptionConverter.java)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.compatibleGet(WorkspaceHttpConnector.java)
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.get(WorkspaceHttpConnector.java)
at com.fr.workspace.engine.channel.http.FunctionalHttpRequest.getToken(FunctionalHttpRequest.java)
at com.fr.workspace.engine.channel.WorkspaceChannelFactory.create(WorkspaceChannelFactory.java)
at com.fr.workspace.engine.client.FineWorkspaceConnector.connect(FineWorkspaceConnector.java)
at com.fr.design.env.DesignerWorkspaceGenerator$1.call(DesignerWorkspaceGenerator.java:53)
at com.fr.design.env.DesignerWorkspaceGenerator$1.call(DesignerWorkspaceGenerator.java:50)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.fr.workspace.engine.exception.WorkspaceConnectionException: Response HTTP/1.1 404  by 192.168.18.189:8085
at com.fr.workspace.engine.channel.http.WorkspaceHttpConnector.execute(WorkspaceHttpConnector.java)
... 12 more
FineReport yzmzz2me6699289 发布于 2023-9-19 16:28
发布于2023-9-19 16:28
对不支持 版本不一致
otziLv5见习互助
发布于2023-9-19 16:30
11不能连10的,你可以在同一台电脑上安装11和10,然后用10去连接10的服务器。
  • 928浏览人数
  • 最后回答于:2023-9-19 16:30
