如题,怎么把data1的数据替换到data中?那个echaets图表引用模板数据集跟这个有些差别,看不太懂 代码: var TABLE_DATA = getData('data1'); option = { tooltip: { trigger: 'item' },
legend: { top: '5%', left: 'center', // doesn't perfectly work with our tricks, disable it selectedMode: false, show: false }, color:['#b7b9eb','#777cb6','#9A60B4','#ef6567', '#f9c956','#3BA272'], series: [ { name: 'Access From', type: 'pie', radius: ['70%', '130%'], center: ['50%', '97%'], // adjust the start angle startAngle: 180, label: { show: false, formatter(param) { // correct the percentage return param.name + ' (' + param.percent * 2 + '%)'; } },
data: [ {value:50,name:'当前值'}, {value:50,name:'目标值'}, { // make an record to fill the bottom 50% value: 50 + 50, itemStyle: { // stop the chart from rendering this piece color: 'none', decal: { symbol: 'none' } }, label: { show: false } } ] } ] }; |
