数据库查询报错
SELECT ddkh, sum(hz - sjsk) AS syhk
  FROM (SELECT (SELECT name
                  FROM bd_customer@ncc0614
                 WHERE pk_customer = a.ccustomerid) AS ddkh, --订单客户
               substr(b.dbizdate, 0, 7) AS ckrq, --入库日期
               sum(b.norigtaxmny) AS hz, --货值
               CASE
                 WHEN sum(c.money_cr) IS NULL THEN
                 ELSE
                  sum(c.money_cr)
               END AS sjsk --实际收款
          FROM ic_saleout_h@ncc0614 a
          LEFT JOIN ic_saleout_b@ncc0614 b
            ON a.cgeneralhid = b.cgeneralhid
          LEFT JOIN so_custaccountdetail@ncc0614 c
            ON b.cgeneralbid = c.cgeneralbid
         WHERE a.dr = 0
           AND b.dr = 0
           AND c.dr = 0
         GROUP BY a.ccustomerid, substr(b.dbizdate, 0, 7)
         ORDER BY substr(b.dbizdate, 0, 7))
 WHERE 1=1
   ${if(len(p1) == 0,"","and ddkh = '" +p1+ "'")}
   ${if(len(p4) == 0,"","and ckrq < " + substr(p4,0,7) + "")}
 GROUP BY ddkh
参数如下所示:
报错如下所示:
FineReport yzm310104 发布于 2023-10-17 16:49
yzm310104Lv2见习互助
发布于2024-4-23 14:23
已解决,substr(p4,0,7) 那儿多了个双引号
发布于2023-10-17 16:51
把这个删了试试
  • yzm310104 yzm310104(提问者) 删除了也不管,错误代码:11300001 数据集配置错误java. sgl SOLException: lon supported Sql92 token at position: 843
    2023-10-17 16:59
用户k6280494Lv6资深互助
发布于2023-10-17 16:54
子查询里不能排序
MKERALv6初级互助
发布于2023-10-17 17:16
看着像是日期的问题,可以先排除一下 ${if(len(p4) == 0,"","and ckrq < " + substr(p4,0,7) + "")} 这语句,${if(len(p4) == 0,"","and ckrq = ‘" + substr(p4,0,7) + "'")}
或者
               CASE
                 ELSE
                  sum(c.money_cr)
               END AS sjsk --实际收款
         WHERE a.dr = 0
           AND b.dr = 0
           AND c.dr = 0
 WHERE 1=1
   and ddkh = "马鞍山市玲俊贸易有限公司"
   and ckrq < "2023-09-01"
 GROUP BY ddkh
这样应该就能定位到具体问题点,希望能帮助到你
  • 357浏览人数
  • 最后回答于:2024-4-23 14:23
