本地预览模板报错
java.lang.RuntimeException: javax.servlet.ServletException: Filter 执行抛出一个异常        com.fr.decision.webservice.filter.CookieCheckFilter.doFilterInternal(CookieCheckFilter.java:39)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)        com.fr.third.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)根本原因。javax.servlet.ServletException: Filter 执行抛出一个异常        com.fr.decision.webservice.filter.SecurityRefererFilter.doFilter(SecurityRefererFilter.java:66)        com.fr.decision.webservice.filter.URICheckFilter.doFilterInternal(URICheckFilter.java:40)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)        com.fr.decision.webservice.filter.CookieCheckFilter.doFilterInternal(CookieCheckFilter.java:37)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)        com.fr.third.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)根本原因。java.lang.AssertionError: com.fr.plugin.system.operation.ops.conf.OpsAuthConfig has the same tableName with com.fr.plugin.system.operation.ops.conf.OpsAuthConfig        com.fr.config.ConfigContext.registerTable(ConfigContext.java)        com.fr.config.ConfigContext.access$100(ConfigContext.java)        com.fr.config.ConfigContext$DefaultInitial.create(ConfigContext.java)        com.fr.config.ConfigContext.getConfigInstance(ConfigContext.java)        com.fr.plugin.system.operation.ops.conf.OpsAuthConfig.getInstance(Unknown Source)        com.fr.plugin.system.operation.ops.filter.impl.OpsFilter.isIgnoreRequest(Unknown Source)        com.fr.plugin.system.operation.ops.filter.impl.OpsFilter.doFilter(Unknown Source)        com.fr.plugin.system.operation.ops.filter.OpsIgnoreFilter$VirtualFilterChain.doFilter(Unknown Source)        com.fr.plugin.system.operation.ops.filter.OpsIgnoreFilter.doFilter(Unknown Source)        com.fr.decision.base.DecisionServletInitializer$5.doFilter(DecisionServletInitializer.java:199)        com.fr.decision.webservice.filter.SecurityRefererFilter.doFilter(SecurityRefererFilter.java:66)        com.fr.decision.webservice.filter.URICheckFilter.doFilterInternal(URICheckFilter.java:40)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)        com.fr.decision.webservice.filter.CookieCheckFilter.doFilterInternal(CookieCheckFilter.java:37)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)        com.fr.third.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)        com.fr.third.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)):注意 主要问题的全部 stack 信息可以在 server logs 里查看
FineReport 不努力会很舒服 发布于 2023-10-23 08:00
  • 166浏览人数
  • 最后回答于:2023-10-23 08:00
