echart如下代码怎么让每个柱子上的文本块颜色不同
  此示例下载自 https://echarts.apache.org/examples/zh/editor.html?c=bar-waterfall
<!DOCTYPE html>
<html lang="zh-CN" style="height: 100%">
<head>
  <meta charset="utf-8">
</head>
<body style="height: 100%; margin: 0">
  <div id="container" style="height: 100%"></div>
  <script type="text/javascript" src="echarts.min.js"></script>
  <script type="text/javascript">
    var dom = document.getElementById('container');
    var myChart = echarts.init(dom, null, {
      renderer: 'canvas',
      useDirtyRect: false
    var app = {};
    var option;
    option = {
      title: {
        text: 'Waterfall Chart',//主标题文本超链接
        subtext: 'Living Expenses in Shenzhen'//副标题文本超链接。
      tooltip: {
        trigger: 'axis',
        axisPointer: {
          type: 'shadow'//指示器类型 阴影指示器
        formatter: function (params) {
          var tar = params[1];
          return tar.name + '' + tar.seriesName + ' : ' + tar.value;
      grid: {
        left: '3%',//grid 组件离容器左侧的距离。
        right: '4%',
        bottom: '3%',
        containLabel: true
      xAxis: {
        type: 'category',
        splitLine: { show: false },
        data: ['Total', 'Rent', 'Utilities', 'Transportation', 'Meals', 'Other']
      yAxis: {
        show: false
        // type: 'value'
      series: [
          type: 'bar',
          stack: 'Total',
          itemStyle: {
            borderColor: 'transparent',
            color: 'transparent', // 红色
            // borderRadius: [0, 20, 20, 0],
          emphasis: {
            itemStyle: {
          data: [0, 1700, 1400, 1200, 300, 0]
          type: 'bar',
          stack: 'Total',
          label: {
            show: true,
            position: 'inside',
            color: 'black', // 黑色
            fontWeight: 'bold',
            textStyle: {
              width: 70, // 设置宽度
              height: 30 // 设置高度
            backgroundColor: 'rgba(9,255,6,255)' ,
              // backgroundColor : function(params){
              //   var colorList =['#9df5s4','#9df5s4','#9df5s4','#9df5s4','#9df5s4','#9df5s4'];
              // return colorList[params.dataIndex];
            //   rich:{
            //   width:'50%',
            //   height:'50%',},
          itemStyle: {
            borderRadius: [10, 10, 10, 10],// 设置圆角
            color: function (params) {
              var colorList = ['#c23531', '#2f4554', '#61a0a8', '#d48265', '#c9a665', '#9df5s4'];
          borderColor: 'red',
          data: [2900, 1200, 300, 200, 900, 300]
    if (option && typeof option === 'object') {
      myChart.setOption(option);
    window.addEventListener('resize', myChart.resize);
  </script>
</body>
</html>
JavaScript Vessel1213 发布于 2023-10-31 11:37 (编辑于 2023-10-31 13:53)
悬赏:0 F币 + 添加悬赏
快乐星光Lv5中级互助
发布于2023-10-31 11:52(编辑于 2023-10-31 11:53)
试一下:
yazhouLv6初级互助
发布于2023-10-31 12:48(编辑于 2023-10-31 12:49)
<!DOCTYPE html>
<head>
head>
    <div id="container" style="height: 100%">div>
    <script type="text/javascript" src="js/echarts.min.js">script>
    <script
            var myChart = echarts.init(dom, null, { renderer: 'canvas', useDirtyRect: false });
            var app = {};
            var option;
            option = {
                title: {
                tooltip: {
                    trigger: 'axis',
                    axisPointer: {
                    grid: {
                        right: '4%', bottom: '3%', containLabel: true
                    xAxis: {
                        type: 'category', splitLine: { show: false },
                    yAxis: {
                        show: false
                        // type: 'value'
                    , series: [{
                         type: 'bar',
                         stack: 'Total',
                        itemStyle: {
                        emphasis: {
                            itemStyle: {
                        name: 'Life Cost', type: 'bar',
                        stack: 'Total',
                        label: {
                            show: true, position: 'inside', color: 'black',
                            // 黑色
                            fontWeight: 'bold',
                            textStyle: {
                                width: 70, // 设置宽度
                                height: 30 // 设置高度
                            backgroundColor: 'rgba(9,255,6,255)',// 设置为黑色半透明背景
                            //     var colorList =['#9df5s4','#c9a665','#d48265','#61a0a8','#2f4554','#c23531'];
                            //   return colorList[params.dataIndex];             // }
                            rich: {             //   width:'50%',             //   height:'50%',},
                            itemStyle: {
                            borderColor: 'red',
                if(option && typeof option === 'object'){
            script>
body>
html>
  • 316浏览人数
  • 最后回答于:2023-10-31 13:53
