参数查询控制
需求:报表的参数块中,有很多条件。目前想分为两类;A类有值就按照A条件查询。否则按照B类。
具体:工号有值是按照工号查询。否则按照四级部门查询。
目前:数据条件
where  工号 is not null
${if(len(dpt01)=0,"","  and  mix.单位 = ' "+dpt01+"'")}
${if(len(dpt02)=0,"","  and  mix.一级部门= ' "+dpt02+"'")}
${if(len(dpt03)=0,"","  and  mix.二级部门= ' "+dpt03+"'")}
${if(len(dpt04)=0,"","  and  mix.三级部门= ' "+dpt04+"'")}
${if(len(dpt05)=0,"","  and  mix.四级部门= ' "+dpt05+"'")}
界面:
FineReport 帆软用户FSeepKI7oc 发布于 2023-11-3 17:28 (编辑于 2023-11-3 20:56)
发布于2023-11-3 18:20(编辑于 2023-11-3 21:12)
你现在这样就可以的呀。你直接查询测试看就知道了!不用改什么
where  1=1
${if(len(工号)>0,"and 工号='"+工号+"'","")}
${if(len(工号)>0,"",if(len(dpt01)=0,"","  and  mix.单位 = ' "+dpt01+"'"))}
${if(len(工号)>0,"",if(len(dpt02)=0,"","  and  mix.一级部门 = ' "+dpt02+"'"))}
${if(len(工号)>0,"",if(len(dpt03)=0,"","  and  mix.二级部门 = ' "+dpt03+"'"))}
${if(len(工号)>0,"",if(len(dpt04)=0,"","  and  mix.三级部门 = ' "+dpt04+"'"))}
${if(len(工号)>0,"",if(len(dpt05)=0,"","  and  mix.四级部门 = ' "+dpt05+"'"))}
发布于2023-11-3 17:30
where 1=1 ${if(len(A类)==0," and B类条件"," AND A类条件"}
  • 252浏览人数
  • 最后回答于:2023-11-3 21:12
