求个SQL写法
微信图片_20191028162029.png有A.B两张表,怎么查询可以得出C表
13207222709 发布于 2019-10-28 16:21
qhlLv6中级互助
发布于2019-10-28 16:30
select AA.name,
   A.语文成绩,
   B.数学成绩
from
(select distinct name from A
union
select distinct name from B) AA
left join A
on A.name=AA.name
left join B
on B.name=AA.name
1310415720Lv7中级互助
发布于2019-10-28 16:24(编辑于 2019-10-28 16:25)
select A.语文成绩,B.数学成绩,A.name from A left join  B on A.name=B.name
格调Lv6初级互助
发布于2019-10-28 16:26(编辑于 2019-10-28 16:26)
select a.name,a.语文成绩,b.数学成绩 from A a FULL JOIN B b ON a.name = b.name
萌萌的呆贼Lv4初级互助
发布于2019-10-28 16:41
--第一种
select
name,
sum(ywcj) as ywcj,
sum(sxcj) as sxcj
from
(select name,[语文成绩] as ywcj,0 as sxcj from A
union all
select name,0 as ywcj,[数学成绩] as sxcj from B) as x
group by name
--第二种
select
case when A.name is not null then A.name else B.name end as name,
isnull(A.[语文成绩],0) as ywcj,
isnull(B.[数学成绩],0) as sxcj
from A
full join B
on A.name = B.name
  • 624浏览人数
  • 最后回答于:2019-10-28 16:41
