当前驱动加载路径下驱动未冲突 com.microsoft.sqlserver.jdbc.SQLServerException: 驱动程序无法通过使用安全套接字层(SSL)加密与 SQL Server 建立安全连接。错误:“The server selected protocol version TLS10 is not accepted by client preferences [TLS12]”。 ClientConnectionId:ee8712e6-7037-4162-9f0e-ae3c7ae144af at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:2400) at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1762) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1977) at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:1628) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1459) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:773) at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1168) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1666) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1732) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2907) Caused by: javax.net.ssl.SSLHandshakeException: The server selected protocol version TLS10 is not accepted by client preferences [TLS12] at sun.security.ssl.Alert.createSSLException(Alert.java:131) at sun.security.ssl.Alert.createSSLException(Alert.java:117) at sun.security.ssl.TransportContext.fatal(TransportContext.java:311) at sun.security.ssl.TransportContext.fatal(TransportContext.java:267) at sun.security.ssl.TransportContext.fatal(TransportContext.java:258) at sun.security.ssl.ServerHello$ServerHelloConsumer.onServerHello(ServerHello.java:943) at sun.security.ssl.ServerHello$ServerHelloConsumer.consume(ServerHello.java:869) at sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:377) at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:444) at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:422) at sun.security.ssl.TransportContext.dispatch(TransportContext.java:182) at sun.security.ssl.SSLTransport.decode(SSLTransport.java:152) at sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1397) at sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1305) at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:440) at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1688) ... 8 more 看了之前的答题,有的电脑还是存在以上问题 解决方法: 找到文件>>FineReport_10.0\jre\lib\security\java.security 搜索:jdk.tls.disabledAlgorithms 找到:jdk.tls.disabledAlgorithms=SSLv3,RC4, DES, MD5withRSA, DH keySize < 1024, \ EC keySize < 224, 3DES_EDE_CBC 改为:jdk.tls.disabledAlgorithms=SSLv3,RC4, DES, MD5withRSA, DH keySize < 1024, \ EC keySize < 224, #3DES_EDE_CBC 即:将该最后的“3DES_EDE_CBC”注释掉即可,即改为:#3DES_EDE_CBC 以上这个办法还是不行 但是FR11.0 安装包就可以 部署版就链接不上 |
最佳回答 |
