连接达梦数据库测试连接显示网络通信异常,连接信息确认没有问题
FineReport a0hdWE1e 发布于 2024-1-8 12:01
华莉星宸Lv7资深互助
发布于2024-1-8 12:08
把错误提示贴出来啊
  • a0hdWE1e a0hdWE1e(提问者) dm.jdbc.driver.DMException: 网络通信异常 at dm.jdbc.driver.DBError.throwException(DBError.java:774) at dm.jdbc.a.a.init(DBAccess.java:185) at dm.jdbc.a.a.(DBAccess.java:157) at dm.jdbc.driver.DmdbConnection.openConnection(DmdbConnection.java:638) at dm.jdbc.desc.EP.connect(EP.java:159) at dm.jdbc.desc.EPGroup$EPSelector.select(EPGroup.java:395) at dm.jdbc.desc.EPGroup.connect(EPGroup.java:278) at dm.jdbc.driver.DmDriver.do_connect(DmDriver.java:163) at dm.jdbc.driver.DmDriver.connect(DmDriver.java:449) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2165) Caused by: java.net.BindException: Cannot assign requested address: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at dm.jdbc.a.a.init(DBAccess.java:173) ... 10 more
    2024-01-08 14:37
  • 华莉星宸 华莉星宸 回复 a0hdWE1e(提问者) 应该还是驱动的问题,参考如下的文章 https://blog.csdn.net/qq_36949403/article/details/134782364
    2024-01-08 14:42
  • 440浏览人数
  • 最后回答于:2024-1-8 12:08
