数据连接失败,这是驱动问题吗
当前驱动加载路径:/home/newhope/newhopeapp/tomcat_bi/webapps/webroot/WEB-INF/lib/mysql-connector-java-5.1.49-bin.jar
检测驱动
com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
FineBI 冥河 发布于 2024-1-11 14:25 (编辑于 2024-1-11 14:25)
发布于2024-1-11 14:26
80%是数据库驱动
MySQL数据连接-https://help.fanruan.com/finebi/doc-view-183.html
  • 247浏览人数
  • 最后回答于:2024-1-11 14:26
