202401040027这组数据怎么改成时间模式
FineReport 用户AYnW76920187 发布于 2024-1-18 10:25
发布于2024-1-18 10:31(编辑于 2024-1-18 10:33)
改成yyyy-MM-dd格式参考,其他格式可以继续截取的
CONCATENATE(left("202401040027",4),"-",mid("202401040027",5,2),"-",mid("202401040027",7,2))
CONCATENATE(left("202401040027",4),"-",mid("202401040027",5,2),"-",mid("202401040027",7,2)," ",mid("202401040027",9,2),":",mid("202401040027",11,2),":00")
ID1208Lv6高级互助
发布于2024-1-18 10:34(编辑于 2024-1-18 10:39)
CONCATENATE(FORMAT(LEFT($$$,8),"yyyy-MM-dd")," ",mid($$$,9,2),":",mid($$$,11,2),":00")
  • 171浏览人数
  • 最后回答于:2024-1-18 10:39
