使用eclipse运行帆软应用程序报错.txt [INFO]Starting fine assist... [INFO]Temp file path :C:\Users\ADMINI~1\AppData\Local\Temp [ERROR]Fine assist start failed. [ERROR]java.lang.reflect.InvocationTargetException [INFO]Starting fine runtime... com.fr.invoke.ReflectException: java.lang.reflect.InvocationTargetException at com.fr.invoke.Reflect.on(Unknown Source) at com.fr.invoke.Reflect.call(Unknown Source) at com.fr.jvm.assist.FineAssist.loadNativeLibrary(Unknown Source) at com.fr.jvm.assist.FineAssist.runOnce(Unknown Source) at com.fr.jvm.assist.FineAssist.<clinit>(Unknown Source) at com.fr.runtime.FineRuntime.<clinit>(Unknown Source) at com.fr.start.Designer.main(Unknown Source) at com.fr.StartFRDesigner.main(StartFRDesigner.java:12) Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) ... 8 more Caused by: com.sun.tools.attach.AgentInitializationException: Agent_OnAttach failed at sun.tools.attach.HotSpotVirtualMachine.loadAgentLibrary(HotSpotVirtualMachine.java:65) at sun.tools.attach.HotSpotVirtualMachine.loadAgentPath(HotSpotVirtualMachine.java:88) ... 12 more [ERROR]com.fr.plugin.bridge.FinePluginBridge java.lang.ClassNotFoundException: com.fr.plugin.bridge.FinePluginBridge at com.fr.plugin.Start.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at com.fr.plugin.Start.loadClass(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at com.fr.runtime.FineRuntime.initEncryptedBridge(Unknown Source) at com.fr.runtime.FineRuntime.start(Unknown Source) at com.fr.start.Designer.main(Unknown Source) at com.fr.StartFRDesigner.main(StartFRDesigner.java:12) Caused by: java.lang.ClassFormatError: Incompatible magic value 50661129 in class file com/fr/plugin/bridge/FinePluginBridge at sun.misc.Unsafe.defineClass(Native Method) ... 9 more [INFO]Fine runtime started. [DEBUG]Module not found cluster-collections [DEBUG]Module not found finebi-start-foundation [DEBUG]Module not found finebi-start-direct [DEBUG]Module not found finebi-start-swift [DEBUG]Module not found finebi-decision-dependency [DEBUG]Module not found finebi-update [DEBUG]Module not found decision-bi [DEBUG]Module not found schedule-bi Exception in thread "main" java.lang.NoClassDefFoundError: com/fr/regist/remove/FineLicenseRemoveController at com.fr.license.LicenseActivator.prepare(Unknown Source) at com.fr.module.engine.extension.ActivatorExtension.executePrepare(Unknown Source) at com.fr.module.engine.build.ModuleBuilder.build(Unknown Source) at com.fr.module.engine.build.FineModuleParser.parse(Unknown Source) at com.fr.module.ModuleContext.parseRoot(Unknown Source) at com.fr.start.Designer.main(Unknown Source) at com.fr.StartFRDesigner.main(StartFRDesigner.java:12) Caused by: java.lang.ClassNotFoundException: com.fr.regist.remove.FineLicenseRemoveController at java.net.URLClassLoader$1.run(Unknown Source) at java.net.URLClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) ... 7 more ERROR: Unable to AddCapabilities JVMTI! |
