【求助】帆软报表单位权限设置
image.png我想满足这两个条件其中之一怎么写呀,就是上面的or下面的,目前这样没效果
 ${if(GETUSERDEPARTMENTS(3, 1) == "公司总部", if(len(jydw)==0,"and 1=1"," and co.fromOrgName = '" + jydw + "'"), " and co.fromOrgName = '" + GETUSERDEPARTMENTS(3, 1) + "'")}
  ${if(GETUSERDEPARTMENTS(3, 1) == "公司总部", if(len(cjdw)==0,"and 1=1"," and co.toOrgName = '" + cjdw + "'"), " and co.toOrgName = '" + GETUSERDEPARTMENTS(3, 1) + "'")}
FineReport sl2tap 发布于 2024-2-7 09:34 (编辑于 2024-2-7 10:07)
发布于2024-2-7 09:37(编辑于 2024-2-7 09:48)
复制SQL出来 图片不好改
where 1=1
${if(GETUSERDEPARTMENTS(3, 1) == "公司总部", if(len(jydw)==0,"and (1=1"," and (co.fromOrgName = '" + jydw + "'"), " and (co.fromOrgName = '" + GETUSERDEPARTMENTS(3, 1) + "'")}
  ${if(GETUSERDEPARTMENTS(3, 1) == "公司总部", if(len(cjdw)==0,"or 1=1)"," or co.toOrgName = '" + cjdw + "')"), " or co.toOrgName = '" + GETUSERDEPARTMENTS(3, 1) + "')")}
  • 294浏览人数
  • 最后回答于:2024-2-7 10:07
