服务器和数据库连接都没有改动,昨天都正常,今天突然连接不上了
数据库连接mysql, 一直正常的, 今天突然就报错,测试连接失败. 无从下手,请问是什么原因?
com.fr.third.alibaba.druid.pool.GetConnectionTimeoutException: wait millis 10000, active 0, maxActive 50, creating 1, createElapseMillis 343716
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionInternal(DruidDataSource.java.1839)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionDirect(DruidDataSource.java.1483)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.1463)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.1452)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.100)
com.fr.stable.pool.DataSourceAdapter.getConnection(DataSourceAdapter.java.60)
com.fr.stable.pool.DataSourceAdapterInvertWrapper.getConnection(DataSourceAdapterInvertWrapper.java.153)
com.fr.cbb.dialect.datasource.pool.DataSourceWrapper.getConnection(DataSourceWrapper.java.263)
com.fr.cbb.dialect.datasource.pool.MemoryConnection.create(MemoryConnection.java.187)
com.fr.cbb.dialect.datasource.DataSourceFactory.getConnection(DataSourceFactory.java.71)
com.fr.data.pool.MemoryConnection.create(MemoryConnection.java.125)
com.fr.data.auth.Authentication.authenticate(Authentication.java.50)
com.fr.data.auth.normal.NormalAuthentication.authenticate(NormalAuthentication.java.50)
com.fr.data.impl.JDBCDatabaseConnection.createConnection(JDBCDatabaseConnection.java.343)
com.fr.data.impl.JDBCDatabaseConnection.testConnection(JDBCDatabaseConnection.java.322)
com.fr.data.operator.DataOperator$8.call(DataOperator.java.-1)
java.util.concurrent.FutureTask.run(FutureTask.java.266)
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java.511)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java.624)
java.lang.Thread.run(Thread.java.748)
FineReport 7kitV3l8 发布于 2024-3-5 10:23
发布于2024-3-5 10:33
这个是数据库连接不对了,没有任何改动的话
直接重启数据库服务器,帆软服务器就可以了
  • 7kitV3l8 7kitV3l8(提问者) 是的 重启了数据库服务器还是报错, 然后再重启帆软服务器后,正常了? 请问是什么池满了的原因吗? 可以怎么修改,在哪里调大?
    2024-03-05 10:41
  • snrtuemc snrtuemc 回复 7kitV3l8(提问者) 这个定义数据连接那边有配置项,可以修改看下,关键还是数据库也要配置下
    2024-03-05 10:43
发布于2024-3-5 10:24
  • 478浏览人数
  • 最后回答于:2024-3-5 10:33
