centos7下执行脚本出错
在centos7 下,安装不成功, java环境是jdk 11, 尝试过卸载jdk,问题依旧。
[root@t-finebi-101 sa]# ./linux_unix_FineBI6_0-CN.sh
Unpacking JRE ...
tar: Ignoring unknown extended header keyword `LIBARCHIVE.xattr.com.apple.provenance'
Starting Installer ...
An error occurred:
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
Error log: /tmp/install4jError4911311270537278690.log
        at com.install4j.runtime.installer.frontend.GUIHelper.invokeOnEDT(GUIHelper.java:719)
        at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor.init(AbstractHeadlessScreenExecutor.java:73)
        at com.install4j.runtime.installer.frontend.headless.ConsoleScreenExecutor.<init>(ConsoleScreenExecutor.java:24)
        at com.install4j.runtime.installer.frontend.headless.InstallerConsoleScreenExecutor.<init>(InstallerConsoleScreenExecutor.java:6)
        at com.install4j.runtime.installer.Installer.getScreenExecutor(Installer.java:87)
        at com.install4j.runtime.installer.Installer.runInProcess(Installer.java:56)
        at com.install4j.runtime.installer.Installer.main(Installer.java:45)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:85)
        at com.install4j.runtime.launcher.UnixLauncher.start(UnixLauncher.java:66)
        at install4j.Installer2925447531.main(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
        at java.awt.EventQueue.invokeAndWait(EventQueue.java:1349)
        at java.awt.EventQueue.invokeAndWait(EventQueue.java:1324)
        at com.install4j.runtime.installer.frontend.GUIHelper.invokeOnEDT(GUIHelper.java:715)
        ... 13 more
Caused by: java.lang.NullPointerException
        at sun.awt.FontConfiguration.getVersion(FontConfiguration.java:1264)
        at sun.awt.FontConfiguration.readFontConfigFile(FontConfiguration.java:219)
        at sun.awt.FontConfiguration.init(FontConfiguration.java:107)
        at sun.awt.X11FontManager.createFontConfiguration(X11FontManager.java:774)
        at sun.font.SunFontManager$2.run(SunFontManager.java:441)
        at java.security.AccessController.doPrivileged(Native Method)
        at sun.font.SunFontManager.<init>(SunFontManager.java:386)
        at sun.awt.FcFontManager.<init>(FcFontManager.java:35)
        at sun.awt.X11FontManager.<init>(X11FontManager.java:57)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
        at java.lang.Class.newInstance(Class.java:442)
        at sun.font.FontManagerFactory$1.run(FontManagerFactory.java:83)
        at sun.font.FontManagerFactory.getInstance(FontManagerFactory.java:74)
        at sun.font.SunFontManager.getInstance(SunFontManager.java:250)
        at sun.font.FontDesignMetrics.getMetrics(FontDesignMetrics.java:264)
        at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:1125)
        at javax.swing.JComponent.getFontMetrics(JComponent.java:1626)
        at javax.swing.text.WrappedPlainView.updateMetrics(WrappedPlainView.java:318)
        at javax.swing.text.WrappedPlainView.updateChildren(WrappedPlainView.java:297)
        at javax.swing.text.WrappedPlainView.insertUpdate(WrappedPlainView.java:463)
        at javax.swing.plaf.basic.BasicTextUI$RootView.insertUpdate(BasicTextUI.java:1616)
        at javax.swing.plaf.basic.BasicTextUI$UpdateHandler.insertUpdate(BasicTextUI.java:1875)
        at javax.swing.text.AbstractDocument.fireInsertUpdate(AbstractDocument.java:201)
        at javax.swing.text.AbstractDocument.handleInsertString(AbstractDocument.java:748)
        at javax.swing.text.AbstractDocument.insertString(AbstractDocument.java:707)
        at javax.swing.text.PlainDocument.insertString(PlainDocument.java:130)
        at javax.swing.text.DefaultEditorKit.read(DefaultEditorKit.java:273)
        at javax.swing.JEditorPane.setText(JEditorPane.java:1416)
        at javax.swing.JEditorPane.<init>(JEditorPane.java:290)
        at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor.createEditorPane(AbstractHeadlessScreenExecutor.java:357)
        at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor.initFontManager(AbstractHeadlessScreenExecutor.java:309)
        at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor.access$400(AbstractHeadlessScreenExecutor.java:28)
        at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor$2.run(AbstractHeadlessScreenExecutor.java:77)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:301)
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
        at java.awt.EventQueue.access$500(EventQueue.java:97)
        at java.awt.EventQueue$3.run(EventQueue.java:709)
        at java.awt.EventQueue$3.run(EventQueue.java:703)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
FineBI 帆软用户jUdjdAXRtC 发布于 2024-3-5 11:34
发布于2024-3-5 11:36(编辑于 2024-3-5 11:40)
重装jdk,安装版本为1.8的吧。把之前的jdk全部删除干净
按这里的方法删除原来的jdk。是可以的
CentOS 卸载、安装JDK_centos卸载jdk-CSDN博客
  • 帆软用户jUdjdAXRtC 帆软用户jUdjdAXRtC(提问者) 没有安装任何java环境 [root@t-finebi-101 sa]# rpm -qa |grep java [root@t-finebi-101 sa]#
    2024-03-05 11:38
  • CD20160914 CD20160914 回复 帆软用户jUdjdAXRtC(提问者) 没有安装的话,你按上面教程下载jdk,安装jdk并设置环境变量
    2024-03-05 11:39
  • 帆软用户jUdjdAXRtC 帆软用户jUdjdAXRtC(提问者) 机器是干净的,一开始安装了: jdk-8u152-linux-x64.rpm, 但还是安装不了,同样的报错。
    2024-03-05 11:39
  • CD20160914 CD20160914 回复 帆软用户jUdjdAXRtC(提问者) 不要安装rpm的格式。要安装gz的格式
    2024-03-05 11:40
  • CD20160914 CD20160914 回复 帆软用户jUdjdAXRtC(提问者) 用gz的格式去安装看。
    2024-03-05 11:40
  • 244浏览人数
  • 最后回答于:2024-3-5 11:40
