看我的写法有问题吗,下面的单独执行有数据,全部一起就得不到JG值
select
sys_guid() as id,
'SEP' AS diseasetype,
qybah as pat_id,
'CM-0-1-3-1' as SUBMITNAME,
listagg(jg,',') within group(order by jg) as  pat_value,
sysdate as createtime,
''updatetime
 from
(select distinct T.qybah,
NCV2.VALUE as jg
from BA_SYJBK t
join ncis.BA_SYZDK a on a.syxh=t.syxh
join ncis.JY_NCIS_VALUE ncv2 on
 (SUBSTR(a.bzbm,1,3)=SUBSTR(ncv2.REMARK,1,3)or SUBSTR(t.zyzdbm,1,5)=SUBSTR(ncv2.REMARK,1,5))
and ncv2.diseasetype='SEP' and ncv2.submitname='CM-0-1-3-1' and T.qybah='798887' AND 'SEP'='SEP'
group by qybah
其他问题 yzm302462 发布于 2024-4-28 10:27 (编辑于 2024-4-28 10:28)
悬赏:0 F币 + 添加悬赏
华莉星宸Lv6高级互助
发布于2024-4-28 10:29
看着没什么问题,你这是报错了?
select
 sys_guid() as id,
 qybah as pat_id,
 listagg(jg, ',') within group(order by jg) as pat_value,
 '' updatetime
  from (select distinct T.qybah,
                         NCV2.VALUE as jg
           from BA_SYJBK t
             on a.syxh = t.syxh
          (SUBSTR(a.bzbm, 1, 3) = SUBSTR(ncv2.REMARK, 1, 3) or
          SUBSTR(t.zyzdbm, 1, 5) = SUBSTR(ncv2.REMARK, 1, 5))
       where ncv2.diseasetype = 'SEP'
       and ncv2.submitname = 'CM-0-1-3-1'
       and T.qybah = '798887'
       AND 'SEP' = 'SEP'
 group by qybah
  • yzm302462 yzm302462(提问者) 没报错,就是全部执行后,Jg为空,但是单独执行下面的语句,又有值
    2024-04-28 10:35
  • 华莉星宸 华莉星宸 回复 yzm302462(提问者) select里面,只执行这段看看,select qybah as pat_id, listagg(jg, \',\') within group(order by jg) as pat_value from ....
    2024-04-28 10:41
  • 43浏览人数
  • 最后回答于:2024-4-28 10:29
