sql里面嵌套写if条件参数失效,该如何修改
SELECT
  DISTINCT STATUS
FROM
  DM.CT_TRAIN_PLAN p
left join (select FID,MAX(TO_CHAR(CREATETIME,'yyyy-mm')) as TSDATE FROM CT_PLAN_TSRECORD GROUP BY FID) d on d.FID = p.FID
where 1=1
${if(len(pv1) = 0,"",if(pv12=="培训时间","and p.FYEAR||'-'||p.FMONTH >='" + pv1 + "'","and d.TSDATE >='" + pv1 + "'")}
${if(len(pv1) = 0,"",if(pv12=="培训时间","and p.FYEAR||'-'||p.FMONTH <='" + pv8 + "'","and d.TSDATE <='" + pv8 + "'")}
FineReport 李9 发布于 2024-5-6 11:43
发布于2024-5-6 11:47
最后少了后面一个括号
SELECT
  DISTINCT STATUS
FROM
  DM.CT_TRAIN_PLAN p
where 1=1
${if(len(pv1) = 0,"",if(pv12=="培训时间","and p.FYEAR||'-'||p.FMONTH >='" + pv1 + "'","and d.TSDATE >='" + pv1 + "'"))}
${if(len(pv1) = 0,"",if(pv12=="培训时间","and p.FYEAR||'-'||p.FMONTH <='" + pv8 + "'","and d.TSDATE <='" + pv8 + "'"))}
发布于2024-5-6 11:45(编辑于 2024-5-6 11:48)
SELECT
  DISTINCT STATUS
FROM
  DM.CT_TRAIN_PLAN p
where 1=1
${if(len(pv1) = 0,"",if(pv12=="培训时间","and p.FYEAR||'-'||p.FMONTH >='" + pv1 + "' and p.FYEAR||'-'||p.FMONTH <='" + pv8 + "'","and d.TSDATE >='" + pv1 + "' and d.TSDATE <='" + pv8 + "'"))}
发布于2024-5-6 11:46(编辑于 2024-5-6 11:48)
第二个不对吧
SELECT
  DISTINCT STATUS
FROM
  DM.CT_TRAIN_PLAN p
where 1=1
${if(len(pv8) = 0,"",if(pv12=="培训时间","and p.FYEAR||'-'||p.FMONTH <='" + pv8 + "'","and d.TSDATE <='" + pv8 + "'"))}
  • 165浏览人数
  • 最后回答于:2024-5-6 11:48
