数据集中条件判断
请问如下数据集中的条件判断如何修改:
当$fine_username在数据表[user]中能找到时,执行select 2 不然执行select 1
 where 1=1
 ${if("select count(1) FROM [dbo].[user]where [fine_usercode]='" + fine_username + "'" == 0,"and select 1","and select 2")}
FineReport ran1025 发布于 2024-5-13 11:48 (编辑于 2024-5-13 11:52)
发布于2024-5-13 11:54(编辑于 2024-5-13 11:57)
需要sql函数判断
 where 1=1
 ${if(sql("数据连接名","select count(1) FROM [dbo].[user]where [fine_usercode]='" + fine_username + "'" ,1,1)== 0,"and select 1","and select 2")}
发布于2024-5-13 11:50
select * from table where 1=1
${if(len(vs)=0,"","and cs='"+cs+"'")}
  • 142浏览人数
  • 最后回答于:2024-5-13 11:57
