var task=FR.remoteEvaluate('=sql("BI数仓"," SELECT Staff_Type FROM DWS_STAFF_LEVEL WHERE Staff_Number='${fine_username}'",1,1)');
var task=FR.remoteEvaluate('=sql("BI数仓"," SELECT Staff_Type FROM DWS_STAFF_LEVEL WHERE Staff_Number='"+$fine_username+"'",1,1)');
var task=FR.remoteEvaluate('=sql("BI数仓"," SELECT Staff_Type FROM DWS_STAFF_LEVEL WHERE Staff_Number= ${fine_username}",1,1)');
var task=FR.remoteEvaluate('=sql("BI数仓"," SELECT Staff_Type FROM DWS_STAFF_LEVEL WHERE Staff_Number=\''+$fine_username+'\'",1,1)');
