数据查询不返回查询值
执行语句:
Exec CreateReceivalReport '2024-03-01','2024-03-31','ping2024','1008','','','006',0,0,'1',0
SELECT sum(thisaramount) as amount from(
Select b.Code,b.Customer,a.*,b.StopFlag
 from ReceivalReport a,Customer b
 where a.CustomerID=b.CustomerID
and TerminalName='ping2024'
 )a
FineReport bird090 发布于 2024-6-4 17:47
悬赏:13 F币 + 添加悬赏
bird090Lv3见习互助
发布于2024-6-7 09:20
无法解决
发布于2024-6-4 17:49
帆软不支持这写法
你把最后的查询改到存储过程里面吧
用户k6280494Lv6资深互助
发布于2024-6-4 17:50
  • 184浏览人数
  • 最后回答于:2024-6-7 09:20
