数据集中if参数like的实现
数据集中的参数company_code是一个字符串,值是逗号分隔的company_code,比如“000000,000001,0000002”,需要实现如果company_code包含000000,那么拼接 AND company_code in  ('" + company_code + "'),否则拼接
AND company_code in (select company_code  from  b )。下面的数据集是不对的,会导致不识别参数,请问该如何实现?
select *  from a
where 1=1
${if(company_code  LIKE '%000000%', " AND company_code in  ('" + company_code + "')", "AND company_code in (select company_code  from dim_company4select union select 'all') ")}
FineReport yzmaen2h6992354 发布于 2024-7-9 11:53 (编辑于 2024-7-9 11:55)
发布于2024-7-9 11:55(编辑于 2024-7-9 11:58)
${if(find("000000",company_code)<=0, " AND company_code in  ('" + company_code + "')",
改成like了
${if(find("000000",company_code)>0, " AND company_code in  ('" + company_code + "')", "AND company_code in (select company_code  from dim_company4select union select 'all') ")}
发布于2024-7-9 11:56
select *  from a
where 1=1
  • 152浏览人数
  • 最后回答于:2024-7-9 11:58
