如何查询报表是否挂出
可以通过帆软的数据库查到报表是否被挂出吗,或者查到在目录就行,哪个表可以查到
FineReport 帆软用户mKLY1SAUyD 发布于 2024-7-10 11:30
发布于2024-7-10 11:43
查询报表目录
select id1,id2,id3,id4,concat(lv1, '/', lv2,  concat( '/', lv3 ), concat( '/', lv4 )) as dictory ,lv1 ,lv2 ,lv3 ,lv4 ,paths from
(select a.id as id1,b.id as id2,c.id as id3,d.id as id4,a.displayName as lv1 ,b.displayName as lv2 ,c.displayName as lv3 ,d.displayName as lv4 ,ifnull( ifnull( b.path, c.path ), d.path ) as paths from fine_authority_object a
left join fine_authority_object b on a.id = b.parentId
left join fine_authority_object c on b.id = c.parentId
left join fine_authority_object d on c.id = d.parentId
where a.parentid = 'decision-directory-root'
order by a.sortIndex ) a
效果
发布于2024-7-10 11:32(编辑于 2024-7-10 11:33)
  • 帆软用户mKLY1SAUyD 帆软用户mKLY1SAUyD(提问者) 谢谢了,我在帮助文档找到这个表了,但是文档写的和我预期的不一样,麻烦你了
    2024-07-10 11:57
  • 92浏览人数
  • 最后回答于:2024-7-10 11:43
