FineBI6.1启动不了,Windows2008R2_x64环境
error.log的报错提示:
七月 17, 2024 9:47:20 上午 org.apache.catalina.core.ApplicationContext log
信息: 1 Spring WebApplicationInitializers detected on classpath
io.grpc.StatusRuntimeException: UNAVAILABLE: Network closed for unknown reason
at io.grpc.stub.ClientCalls.toStatusRuntimeException(ClientCalls.java:271)
at io.grpc.stub.ClientCalls.getUnchecked(ClientCalls.java:252)
at io.grpc.stub.ClientCalls.blockingUnaryCall(ClientCalls.java:165)
at com.fanruan.polars.server.master.MasterServiceGrpc$MasterServiceBlockingStub.getNodesByIdentity(MasterServiceGrpc.java:1498)
at com.fanruan.polars.client.Worker2MasterClient.getRoleInfoByRoleIdentity(Worker2MasterClient.java:176)
at com.fanruan.polars.server.node.RpcMasterServerClient.getRoleInfoByIdentity(RpcMasterServerClient.java:139)
at com.fanruan.polars.server.NodeBuilder.buildMonitor(NodeBuilder.java:272)
at com.fanruan.polars.server.MonitorServer.initNode(MonitorServer.java:93)
at com.fanruan.polars.server.MonitorServer.start(MonitorServer.java:88)
at com.finebi.adapt.polars.impl.polars.LocalMiniProcessStart.lambda$startServer$0(LocalMiniProcessStart.java:157)
at java.lang.Thread.run(Thread.java:750)
output.log的报错提示:
09:48:09 INFO [sync-master-display] sync master node info:
| Sync Worker | Address | Timestamp |
09:48:11 WARN [driver-heartbeater] Exception when trying to compute pagesize, as a result reporting of ProcessTree metrics is stopped
09:48:15 INFO [sync-master-display] sync master node info:
09:48:22 INFO [sync-master-display] sync master node info:
09:48:28 INFO [sync-master-display] sync master node info:
09:48:35 INFO [sync-master-display] sync master node info:
MasterServer stop
09:48:40 INFO [Thread-22] closing xdb db manager
09:48:40 INFO [Thread-22] [xdb]DB manager is closed
如果部署到tomcat也是以上报错
FineBI litao_hao 发布于 2024-7-17 09:53 (编辑于 2024-7-17 09:55)
用户k6280494Lv6资深互助
发布于2024-7-17 09:55
发布于2024-7-17 09:56
你是外接了数据库?你的服务器是集群?
发布于2024-7-17 09:56
配置问题把,我可以的
  • 207浏览人数
  • 最后回答于:2024-7-17 09:56
