班级生产问题
maparray(["2030","2029","2028","2027","2026","2025"], item + range(6) + "")
上面生产的每届班级都是6个,如何生成2030届4个班、2029届6个班、2028届4个班、2027届5个班、2026届5个班、2025届5个班?
FineReport nxwzqy1 发布于 2024-9-2 18:22
发布于2024-9-2 19:01
MAPARRAY(["2030届","2029届","2028届","2027届","2026届","2025届"], IF(item == "2030届", item+MAPARRAY(RANGE(4), item + "班"), IF(item == "2029届",item+MAPARRAY(RANGE(6), item + "班"), IF(item == "2028届", item+MAPARRAY(RANGE(4), item + "班"), IF(item == "2027届", item+MAPARRAY(RANGE(5), item + "班"), IF(item == "2026届", item+MAPARRAY(RANGE(5), item + "班"), IF(item == "2025届", item+MAPARRAY(RANGE(5), item + "班"), [])))))))
超级无敌小熊蛋Lv5初级互助
发布于2024-9-2 18:25
MAPARRAY(["2030届","2029届","2028届","2027届","2026届","2025届"], IF(item == "2030届", MAPARRAY(RANGE(4), item + "班"), IF(item == "2029届", MAPARRAY(RANGE(6), item + "班"), IF(item == "2028届", MAPARRAY(RANGE(4), item + "班"), IF(item == "2027届", MAPARRAY(RANGE(5), item + "班"), IF(item == "2026届", MAPARRAY(RANGE(5), item + "班"), IF(item == "2025届", MAPARRAY(RANGE(5), item + "班"), [])))))))
  • nxwzqy1 nxwzqy1(提问者) 不对,只能显示1班、2班、3班、4班、5班、6班
    2024-09-02 18:33
  • 107浏览人数
  • 最后回答于:2024-9-2 19:01
