Oracle递归函数哪里写错了求指教
1
SQL 姚友林 发布于 2024-9-5 13:54 (编辑于 2024-9-5 19:49)
用户k6280494Lv6资深互助
发布于2024-9-5 13:56(编辑于 2024-9-5 14:40)
SELECT TRIM(REGEXP_SUBSTR(your_column, '[^,]+', 1, LEVEL)) AS split_value
FROM your_table
CONNECT BY REGEXP_SUBSTR(your_column, '[^,]+', 1, LEVEL) IS NOT NULL
AND PRIOR your_column = your_column
AND PRIOR SYS_GUID() IS NOT NULL
AND ROWNUM <= REGEXP_COUNT(your_column, ',') + 1;
更新
FROM your_table
AND PRIOR your_unique_column = your_unique_column  -- 使用表的唯一列来避免跨行递归
AND LEVEL <= REGEXP_COUNT(your_column, ',') + 1;
shirokoLv6资深互助
发布于2024-9-5 14:36(编辑于 2024-9-5 14:48)
select name ,
level as t,
REGEXP_SUBSTR(XM_CODE,'[^,]+',LEVEL) as PROJECT_CODE
from 表
--where XM_CODE
connect by
prior NAME = NAME
and level<=REGEXP_COUNT(XM_CODE,',')+1
and prior dbms_random.value is not null
  • 177浏览人数
  • 最后回答于:2024-9-5 19:49
