有没有大佬帮我修改一下这个公式,为啥我那个I2的参数传不进去
如下图所示,当我输入三个参数后,这个单元格的值根据传的三个参数去查询,但是要做判断,我这个语法该怎么改呢MIN(if(AND(B2 = '02',F2 = '04'),SQL("本机福泉","select khrq from zhxxb_ck where khdh = '{I2}' ",1),if(AND(B2 = '02',F2 = '06'),SQL("本机福泉","select khrq from zhxxb_ck where zhdh = '{I2}' ",1),if(AND(B2 = '03',F2 = '04'),SQL("本机福泉","select khrq from zhxxb_dk where khdh = '{I2}' ",1),if(AND(B2 = '03',F2 = '06'),SQL("本机福泉","select khrq from zhxxb_dk where zhdh = '{I2}' ",1),)))))image.png
FineReport 木子一丶 发布于 2024-10-24 11:56
华莉星宸Lv7资深互助
发布于2024-10-24 11:58
MIN(if(AND(B2 = '02',F2 = '04'),SQL("本机福泉","select khrq from zhxxb_ck where khdh = '"+I2+"' ",1),if(AND(B2 = '02',F2 = '06'),SQL("本机福泉","select khrq from zhxxb_ck where zhdh = '"+I2+"' ",1),if(AND(B2 = '03',F2 = '04'),SQL("本机福泉","select khrq from zhxxb_dk where khdh = '"+I2+"' ",1),if(AND(B2 = '03',F2 = '06'),SQL("本机福泉","select khrq from zhxxb_dk where zhdh = '"+I2+"' ",1))))))
用户k6280494Lv6资深互助
发布于2024-10-24 11:59(编辑于 2024-10-24 11:59)
MIN(if(AND(B2 = '02',F2 = '04'),SQL("本机福泉","select khrq from zhxxb_ck where khdh = '"+I2+"' ",1),if(AND(B2 = '02',F2 = '06'),SQL("本机福泉","select khrq from zhxxb_ck where zhdh = '"+I2+"' ",1),if(AND(B2 = '03',F2 = '04'),SQL("本机福泉","select khrq from zhxxb_dk where khdh = '"+I2+"'",1),if(AND(B2 = '03',F2 = '06'),SQL("本机福泉","select khrq from zhxxb_dk where zhdh = '"+I2+"' ",1),"")))))
  • 木子一丶 木子一丶(提问者) 为什么传了参数查询不出结果呢
    2024-10-24 14:20
  • 用户k6280494 用户k6280494 回复 木子一丶(提问者) 把这个公式直接放在单元格试试SQL("本机福泉","select khrq from zhxxb_dk where zhdh = '"+I2+"' ",1)
    2024-10-24 14:23
  • 95浏览人数
  • 最后回答于:2024-10-24 11:59
