sql求助impala
FineReport 东云川 发布于 2024-10-28 16:45 (编辑于 2024-10-28 16:45)
发布于2024-10-28 16:51(编辑于 2024-10-28 16:53)
impala不像其它数据库提供了PIVOT关键字,那么方便,你参考类似下面的语句吧
SELECT
    salesperson,
    MAX(CASE WHEN month = 'Jan' THEN amount ELSE 0 END) AS Jan,
    MAX(CASE WHEN month = 'Feb' THEN amount ELSE 0 END) AS Feb,
    MAX(CASE WHEN month = 'Mar' THEN amount ELSE 0 END) AS Mar,
    -- 继续添加其他月份...
FROM sales
GROUP BY salesperson
方式二
WITH aggregated_sales AS (
  SELECT
      salesperson,
      COLLECT_LIST(month) AS months,
      COLLECT_LIST(amount) AS amounts
  FROM sales
SELECT
  salesperson,
  months[0] AS month1,
  amounts[0] AS amount1,
  months[1] AS month2,
  amounts[1] AS amount2,
  -- 根据需要添加更多的列...
FROM aggregated_sales;
发布于2024-10-28 16:47
FR-LeonLv4初级互助
发布于2024-10-28 16:55
你直接查一行的union吧
用户Q2815112Lv2见习互助
发布于2024-10-28 16:58(编辑于 2024-10-28 16:59)
使用case when+聚合函数就可以了。如下:
WITH t1 as ( select '昨日库存' as `分类`,8000 as `进出库存` union all select '入库' as `分类`,5000 as `进出库存` union all select '出库' as `分类`,-2000 as `进出库存` union all select '当日库存' as `分类`,11000 as `进出库存` ) select  max(case when `分类` ='昨日库存' then `进出库存` else null end ) as `昨日库存`, max(case when `分类` ='入库' then `进出库存` else null end ) as `入库`, max(case when `分类` ='出库' then `进出库存` else null end ) as `出库`, max(case when `分类` ='当日库存' then `进出库存` else null end ) as `当日库存` FROM t1
  • 124浏览人数
  • 最后回答于:2024-10-28 16:59
