运行模板报错:错误代码:11300001数据集[图一IOT]配置错误出现不支持的SQL92
SELECT * FROM
(SELECT TO_CHAR(TO_DATE(TIME_,'YYYY-MM-DD HH24:MI:SS' ),'MM-DD HH24')AS WORK_TIME,'通道1'AS CLASS ,
ROUND((AVG(CH1_NMHCG)+AVG(CH1_NMHCP))/2,2) AS VALUE
FROM IOT.DAY_MINUTE_RECORD
WHERE 1=1
${IF(LEN(end1)<1,"AND TIME_ LIKE'${end}%'","TO_DATE(TIME_,'YYYY-MM-DD HH24:MI:SS')BETWEEN TO_DATE('"+start1+" 00:00:00','YYYY-MM-DD HH24:MI:SS')AND TO_DATE('"+end1+" 23:59:59','YYYY-MM-DD HH24:MI:SS')")}
GROUP BY TO_CHAR(TO_DATE(TIME_,'YYYY-MM-DD HH24:MI:SS' ),'MM-DD HH24')
UNION ALL
SELECT TO_CHAR(TO_DATE(TIME_,'YYYY-MM-DD HH24:MI:SS' ),'MM-DD HH24')AS WORK_TIME,'通道2'AS CLASS ,
ROUND((AVG(CH2_NMHCG)+AVG(CH2_NMHCP))/2,2) AS VALUE
WHERE 1=1
GROUP BY TO_CHAR(TO_DATE(TIME_,'YYYY-MM-DD HH24:MI:SS' ),'MM-DD HH24'))
ORDER BY WORK_TIME
FineReport 帆软用户mVQ2gDxk8Q 发布于 2024-11-22 10:41
华莉星宸Lv7资深互助
发布于2024-11-22 10:46
SELECT *
  FROM (SELECT TO_CHAR(TO_DATE(TIME_, 'YYYY-MM-DD HH24:MI:SS'), 'MM-DD HH24') AS WORK_TIME,
               '通道1' AS CLASS,
               ROUND((AVG(CH1_NMHCG) + AVG(CH1_NMHCP)) / 2, 2) AS VALUE
         WHERE 1 = 1
         ${IF(LEN(end1) < 1,
                    "AND TIME_ LIKE '"+end+"%'",
                    "TO_DATE(TIME_,'YYYY-MM-DD HH24:MI:SS')BETWEEN TO_DATE('" +
                      start1 +
                      " 00:00:00','YYYY-MM-DD HH24:MI:SS')AND TO_DATE('" + end1 +
                      " 23:59:59','YYYY-MM-DD HH24:MI:SS')") }
         GROUP BY TO_CHAR(TO_DATE(TIME_, 'YYYY-MM-DD HH24:MI:SS'),
                          'MM-DD HH24')
        UNION ALL
               '通道2' AS CLASS,
               ROUND((AVG(CH2_NMHCG) + AVG(CH2_NMHCP)) / 2, 2) AS VALUE
         WHERE 1 = 1
         ${IF(LEN(end1) < 1,
                    "AND TIME_ '"+end+"%'",
                      start1 +
                          'MM-DD HH24'))
 ORDER BY WORK_TIME
用户k6280494Lv6资深互助
发布于2024-11-22 10:47
SELECT * FROM
WHERE 1=1
${IF(LEN(end1)<1,"AND TIME_ LIKE'"+end+"%'","TO_DATE(TIME_,'YYYY-MM-DD HH24:MI:SS')BETWEEN TO_DATE('"+start1+" 00:00:00','YYYY-MM-DD HH24:MI:SS')AND TO_DATE('"+end1+" 23:59:59','YYYY-MM-DD HH24:MI:SS')")}
UNION ALL
WHERE 1=1
ORDER BY WORK_TIME
  • 81浏览人数
  • 最后回答于:2024-11-22 10:47
