判断复选按钮控件是否勾选
var value = _g().getCellValue(0,2,0); // 获取单元格的值
if (value == null || value.length == 0) {
    FR.Msg.alert("提示", "单元格不能为空,请选择一个值!");
    return false;
var $span = $(".fr-checkbox-checkon");
var darray = [];
var $tds = $("td").has($span);
for (var i = 0, len = $tds.length; i < len; i ++) {
   var id = $($tds[i]).attr("id");
var idn = id.replace("A","B");
var vv=document.getElementById(idn).innerHTML;
  darray.push(vv);
FR.doURLPDFPrint("${sevletURL}ReportServer?reportlet=/PrintCol.cpt&ID="+darray);
FineReport yyfnet 发布于 2024-12-11 13:26
发布于2024-12-11 13:40
wkx1Lv4见习互助
发布于2024-12-11 13:48
if (isAllChecked = true)
判断控件状态为是否为:选中;不用判断值
  • 36浏览人数
  • 最后回答于:2024-12-11 13:48
