启动tomcat报错
昨天还好好的 今天自己挂掉了 报错重新启动报错
tomcat可以正常进入
28-Feb-2025 13:16:00.137 SEVERE [main] org.apache.catalina.startup.HostConfig.deployDirectory Error deploying web application directory [/opt/module/apache-tomcat-9.0.91/webapps/webroot]
java.lang.IllegalStateException: Error starting child
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:602)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:571)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:603)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1175)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1888)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:112)
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1086)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:470)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1584)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:312)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:109)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:385)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:332)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:776)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:721)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1203)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1193)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:134)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:749)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:211)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:415)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:878)
at org.apache.catalina.startup.Catalina.start(Catalina.java:735)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473)
Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/webroot]]
at org.apache.catalina.util.LifecycleBase.handleSubClassException(LifecycleBase.java:402)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:179)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:599)
... 37 more
Caused by: com.fr.stable.lifecycle.FineLifecycleFatalError: FineAssist version not match the project version, externalPath [not external]
at com.fr.runtime.FineRuntime.createVersionNotMatchFatalError(FineRuntime.java)
at com.fr.runtime.FineRuntime.handleEncryptedBridgeError(FineRuntime.java)
at com.fr.runtime.FineRuntime.start(FineRuntime.java)
at com.fr.module.ModuleContext.
at com.fr.general.CloudCenter.
at com.fr.startup.MockServletStartUp.initHyperlink(MockServletStartUp.java:121)
at com.fr.startup.MockServletStartUp.start(MockServletStartUp.java:84)
at com.fr.startup.FineWebApplicationInitializer.onStartup(FineWebApplicationInitializer.java:50)
at com.fr.third.springframework.web.SpringServletContainerInitializer.onStartup(SpringServletContainerInitializer.java:169)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4438)
... 38 more
Caused by: java.lang.ClassFormatError: Incompatible magic value 50661129 in class file com/fr/plugin/bridge/FinePluginBridge
at java.lang.ClassLoader.defineClass1(Native Method)
at com.fr.plugin.Start$Jdk8Helper.defineClass(Start.java)
at com.fr.plugin.Start.findClass(Start.java)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at com.fr.plugin.Start.loadClass(Start.java)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:348)
at com.fr.runtime.FineRuntime.initEncryptedBridge(FineRuntime.java)
... 48 more
FineReport yzmxCiaN7922059 发布于 2025-2-28 13:20 (编辑于 2025-2-28 13:21)
yzmxCiaN7922059Lv3见习互助
发布于2025-2-28 16:24
将Tomcat的temp和work文件夹的内容删掉就可以了
发布于2025-2-28 13:22
发布于2025-2-28 13:25
你是不是没有正式购买?
注册简介 https://help.fanruan.com/finereport/doc-view-281.html
  • yzmxCiaN7922059 yzmxCiaN7922059(提问者) 购买了
    2025-02-28 13:26
  • snrtuemc snrtuemc 回复 yzmxCiaN7922059(提问者) 那就服务器不稳定,jar包有冲突,可以的话,升级最新版本,也可以找帆软技术咨询看看具体原因
    2025-02-28 13:27
  • 50浏览人数
  • 最后回答于:2025-2-28 16:24
