获取当前所有周及开始时间结束时间,和对应的上周数据
年度周次本周开始时间本周结束时间上周所对应年上周所对应周
oracle数据库,我想获取这6个字段,该怎么写,每周从周一到周日视为一周,写了很多sql到跨年的时候都处理不好,有什么帆软公式可以替代吗?或者下面的sql怎么修改能保证跨年时数据展示正确
WITH DateInfo AS (
    SELECT
        TO_CHAR(dt, 'YYYY') AS Year,
        TO_CHAR(dt, 'IW') AS Week,
        TRUNC(dt, 'IW') AS WeekStart,
        TRUNC(dt, 'IW') + 6 AS WeekEnd,
        TO_CHAR(TRUNC(dt, 'IW') - 7, 'YYYY') AS LastYear,
        TO_CHAR(TRUNC(dt, 'IW') - 7, 'IW') AS LastWeek
    FROM (
        SELECT TRUNC(SYSDATE, 'YYYY') + LEVEL - 1 AS dt
        FROM dual
        CONNECT BY LEVEL <= ADD_MONTHS(TRUNC(SYSDATE, 'YYYY'), 12) - TRUNC(SYSDATE, 'YYYY')
SELECT DISTINCT
    Year,
    Week,
    TO_CHAR(WeekStart, 'YYYY/MM/DD HH24:MI') AS WeekStart,
    TO_CHAR(WeekEnd, 'YYYY/MM/DD HH24:MI') AS WeekEnd,
    LastYear,
    LastWeek
FROM DateInfo
WHERE Year = TO_CHAR(SYSDATE, 'YYYY')
ORDER BY WeekStart;
FineReport RJ6688 发布于 2025-3-18 11:33
发布于2025-3-18 11:36(编辑于 2025-3-18 11:37)
大哥别折腾了,逻辑太多的判断,直接做一张时间维度表,直接关联一下就行了!!
我们就自己创建了一张维度表,然后里面有对应自定义的季度开始日期,自定义周范围(自然周,非自然周)以及业务需要的一切时间计算周期字段,都放在这张维度表中去!!
发布于2025-3-18 11:39(编辑于 2025-3-18 11:41)
WITH RECURSIVE DateRange AS (
SELECT
TRUNC ( SYSDATE, 'IW' ) - INTERVAL '7' DAY * LEVEL + INTERVAL '1' DAY AS week_start_date,
TRUNC ( SYSDATE, 'IW' ) - INTERVAL '7' DAY * LEVEL + INTERVAL '6' DAY AS week_end_date,
TO_CHAR ( TRUNC ( SYSDATE, 'IW' ) - INTERVAL '7' DAY * LEVEL, 'YYYY' ) AS YEAR,
TO_CHAR ( TRUNC ( SYSDATE, 'IW' ) - INTERVAL '7' DAY * LEVEL, 'IW' ) AS week_number
FROM
DUAL CONNECT BY LEVEL <= CEIL (
MONTHS_BETWEEN ( TRUNC ( ADD_MONTHS ( SYSDATE, 11 ), 'YYYY' ) - INTERVAL '1' DAY, TRUNC ( SYSDATE, 'YYYY' ) ) / 12
) * 52 +
CASE
WHEN TO_CHAR ( TRUNC ( SYSDATE, 'YYYY' ), 'DD' ) > TO_CHAR (
TRUNC (
ADD_MONTHS ( TRUNC ( SYSDATE, 'YYYY' ), - ( TO_CHAR ( TRUNC ( SYSDATE, 'YYYY' ), 'MM' ) - 1 ) ),
'IW'
'DD'
) THEN
1 ELSE 0
END
SELECT
d.year AS "年度",
d.week_number AS "周次",
d.week_start_date AS "本周开始时间",
d.week_end_date AS "本周结束时间",
CASE
WHEN d.week_number = 1 THEN
TO_CHAR ( ADD_MONTHS ( TRUNC ( d.week_start_date, 'YYYY' ) - INTERVAL '1' DAY, 12 ), 'YYYY' ) ELSE TO_CHAR ( d.week_start_date - INTERVAL '7' DAY, 'YYYY' )
END AS "上周所对应年",
CASE
TO_CHAR ( ADD_MONTHS ( TRUNC ( d.week_start_date, 'YYYY' ) - INTERVAL '1' DAY, 12 ) - INTERVAL '7' DAY, 'IW' ) ELSE TO_CHAR ( d.week_start_date - INTERVAL '7' DAY, 'IW' )
END AS "上周所对应周"
FROM
DateRange d
ORDER BY
d.year,
d.week_number
  • 41浏览人数
  • 最后回答于:2025-3-18 11:41
