获取复选下拉框最大值和最小值
怎么获取复选下拉框最大值和最小值,比如下拉框数据选择了2025-01,2025-02,2025-03
FineReport yzmXrTpA3762457 发布于 2025-4-15 11:44 (编辑于 2025-4-15 11:45)
发布于2025-4-15 11:46(编辑于 2025-4-15 11:55)
确保都是这个格式的,那是可以的
最大值:LEFT(max(SPLIT(MAPARRAY(split($控件名,","),REPLACE(item,"-","")),",")),4)+"-"+RIGHT(max(SPLIT(MAPARRAY(split($控件名,","),REPLACE(item,"-","")),",")),2)
最小值:LEFT(min(SPLIT(MAPARRAY(split($控件名,","),REPLACE(item,"-","")),",")),4)+"-"+RIGHT(min(SPLIT(MAPARRAY(split($控件名,","),REPLACE(item,"-","")),",")),2)
华莉星宸Lv7资深互助
发布于2025-4-15 11:51
直接
min($控件名)
max($控件名)
runnerLv7资深互助
发布于2025-4-15 11:54
INDEXOFARRAY(SORTARRAY(参数),1) 最小值
INDEXOFARRAY(SORTARRAY(参数),-1) 最大值
CovidLv3高级互助
发布于2025-4-15 11:56
FORMAT(TODATE(max(MAPARRAY(SPLIT("2025-01,2025-02,2025-03",","),DATETONUMBER(CONCATENATE(item,"-01"))))),"yyyy-MM")
  • 41浏览人数
  • 最后回答于:2025-4-15 11:56
